Trouble getting tow hitch wiring harness to work
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beverlytaco, Sep 27, 2016.
  1. Sep 27, 2016 at 1:29 PM
    beverlytaco
    beverlytaco [OP] Well-Known Member
    2017 TRD off road double cab
    2017 TRD Off road DC with tow package. I have a 5 pin on the trailer and i'm using an adapter to plug into the 7 pin. All i get are the reverse lights to work. Anybody having similar issues? I have trailer brakes.
  2. Sep 27, 2016 at 1:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Simply use a DVM to verify the pin out on the truck. If good,
    Plug in the adapter and verify the pin out on it. If good,
    Use a jumper and test each pin on the trailer to the adapter plug on the truck.
    You have to isolate the problem. It can only be one of three things. Truck issue, adapter issue, trailer wiring issue.
  3. Sep 27, 2016 at 1:47 PM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    I didn't think 5-pin connectors carried reverse signal? Left, right, brake, tail and ground. You want reverse, you need the 7-pin on the trailer.
    Edit: Misread your post. Either way if your getting reverse lighting out of the 7 into the 5 through the adapter there's something wrong with the adapter or your trailers wiring.
  4. Sep 27, 2016 at 1:52 PM
    Threerun
    Threerun Well-Known Member
    Lost in Montana *recalculating*
    2016 Silverado LTZ
    6.2L 8spd stock
    Just for giggles- try cleaning off the terminals on your 5 pin with a shot of brake cleaner. Also hit the adapter, both ends. Let them dry thoroughly then test it.
    Little trick that works for me almost 75% of the time when confronted with that issue.
  5. Sep 27, 2016 at 2:02 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    4 and 5 pin connectors get there brake through the turn signal wires. So it's left turn, right turn, trailer markers (parking light) and ground. 5 pin adds reverse
