Trouble going straight over 50 mph
Discussion in '1st Gen. Tacomas (1995-2004)' started by akrinar, Feb 19, 2020.
  1. Feb 21, 2020 at 5:41 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    second this! Easy to check. Unlock steering, grab shaft under dash, try to move steering wheel. Any movement makes it worth the time and effort to do the mod.
    Gyrkin[QUOTED] likes this.
  2. Feb 21, 2020 at 7:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Aftermarket or OEM rack?
  3. Feb 21, 2020 at 9:43 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    did you get it aligned after replacing the rack?
    In the end, the solution is more than likely the same as was discussed earlier. worn out control arm bushings, old ball joints, and poor alignment. If you didn't get it aligned after the rack replacement, definitely do that, and see what your numbers end up being.
  4. Feb 21, 2020 at 11:40 PM
    gunnar#1
    gunnar#1 Well-Known Member
    sam
    Mesa
    2001 Tacoma 4x4
    Silver xtra-cab,old man emu 3 inch lift, 2016 wheels, arb front bumper, receiver hitch, Automatic transmission cooler, tundra front calipers, new frame.
    oem rack
