Trouble in TPS p1022
Discussion in '1st Gen. Tacomas (1995-2004)' started by kcsurfs70, Oct 20, 2017.
  1. Oct 20, 2017 at 2:47 PM
    kcsurfs70
    kcsurfs70 [OP] New Member
    2003 3.4l taco throwing code and going into limp mode. Any suggestions would help thinking of buying used Throttle Body of ebay. Truck seems to do it when heated hot days, has anyone bypassed the coolant line? I have tried to look up 4 prong tps sensor to no luck. Help
  2. Oct 20, 2017 at 3:02 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Folks have sourced that TPS from Aisia and Europe. As I recall it had to be a certain quantity. I believe someone found a replacement that worked from a different application.
    Give it some time and they might chime in.
    Yes, historically heat seems to be a player in the deterioration and yes folks have bypassed the coolant lines in an effort to keep it cooler. I never followed the issue all that closely.
  3. Oct 20, 2017 at 3:09 PM
    kcsurfs70
    Thanks for the input!
