Trouble Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACST1, Jul 16, 2022.
  1. Jul 16, 2022 at 3:36 AM
    TACST1
    TACST1 [OP] Member
    Joe
    2010 Tacoma TRD
    Hood Decal
    I have a 2010 tacoma TRD 4x4 6cyl. The check engine light and the slip indicator light came on. I had them reset. After a couple of days the trouble lights came back on. Any help on this one, besides taking the truck to a dealer.
    Thank you
    Joe Kusnersyk
  2. Jul 16, 2022 at 3:41 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Step one: find out what codes it's telling you.
  3. Jul 16, 2022 at 3:47 AM
    TACST1
    TACST1 [OP] Member
    Joe
    2010 Tacoma TRD
    Hood Decal
    P0122
  4. Jul 16, 2022 at 6:25 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Throttle Position Sensor
  5. Jul 16, 2022 at 10:25 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    P0122 - Throttle / Pedal Position Sensor / Switch "A" Circuit Low Input.
    HINT: These DTCs relate to the Throttle Position (TP) sensor.
    DESCRIPTION:
    This ETCS (Electronic Throttle Control System) does not use a throttle cable. The Throttle Position (TP) sensor is mounted on the throttle body, and detects the opening angle of the throttle valve. This sensor is a non-contact type, and uses Hall-effect elements, in order to yield accurate signals, even in extreme driving conditions, such as at high speeds as well as very low speeds. The TP sensor has two sensor circuits which each transmits a signal, VTA1 and VTA2. VTA1 is used to detect the throttle valve angle and VTA2 is used to detect malfunctions in VTA1. The sensor signal voltages vary between 0 V and 5 V in proportion to the throttle valve opening angle, and are transmitted to the VTA terminals of the ECM. As the valve closes, the sensor output voltage decreases and as the valve opens, the sensor output voltage increases. The ECM calculates the throttle valve opening angle according to these signals and controls the throttle actuator in response to driver inputs. These signals are also used in calculations such as air-fuel ratio correction, power increase correction and fuel-cut control.
    Detection Conditions:
    Output voltage of VTA1 0.2 V or less for 2 seconds (1 trip detection logic)
    Probable Trouble Areas:
    •TP sensor (built into throttle body)
    •Short in VTA1 circuit
    •Open in VC circuit
    •ECM
    Check the wiring and Harness going to the Throttle Position Sensor.
