Trouble moving in 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KanakaRebel, May 8, 2020.
  1. May 10, 2020 at 12:23 PM
    #41
    KanakaRebel
    KanakaRebel [OP] Well-Known Member
    Kauai, HI
    2009 Tacoma 4x4 Single Cab
    You know, I honestly wish I could give you a solid answer to this, but living on an island like where I’m at, I can honestly say I haven’t even gotten to 60mph in a while. My average speed daily is 30mph, maybe 45mph being my top speed. It doesn’t help that my daily commute to work is only 3 miles round trip, so I make it into 4th gear for less than a minute and then I’m done. If I can remember correctly the last time I was in 5th gear, at 60mph I was probably turning no more than 2300rpm, plus or minus 100 on flat ground. Going uphill with a slight 3-4% grade, I’d probably be turning closer to 27-2800rpm and I’d still have room to give it more gas and go a little faster. Never had the feeling that I’d have to downshift for any reason going uphill. Before I came to 285s, I was running true 33s and my rpm seemed about the same driving wise. Original owner planned on running 35s with this truck but never got around to it. He was hesitant on running 35s with the 4 banger as his daily driver.
  2. May 11, 2020 at 5:56 AM
    #42
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Everything has to match as they are all linked together otherwise the one with the higher ratio will try to drive the other faster. Tire size mismatch will have the same effect.
    dk_crew likes this.
  3. May 11, 2020 at 6:42 AM
    #43
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    I would use the 'ol lift the truck and spin the wheel 2 revs and count the drive shaft revs to convince myself the ratios of the front and rear diffs match..... scenario sounds a lot like using 4wd on dry pavement and trying to pull a U turn..... which i'd expect a mismatched gear ratio to feel like as well..... or maybe broken teeth on ring/pinion.
    Good luck and hope you figure it out...
  4. May 11, 2020 at 4:00 PM
    #44
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You definitely would know about a missing tooth.
