Trouble Removing Bolt From Upper Control Arm With Pics
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deere9798, Jul 17, 2014.
  1. Jul 17, 2014 at 5:57 PM
    Deere9798
    Deere9798 [OP] Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Hello. New member here. While trying to replace my left front wheel bearing on my 2001 Toyota Tacoma 4cyl 5spd 4x4 ... I could not get the bolt out of the upper control arm. If anyone has experienced this issue I would value your input.
    Thanks,
    Charlie
  2. Jul 17, 2014 at 6:02 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    You need a ball joint separator......they rent them at local autoparts store.
  3. Jul 17, 2014 at 6:19 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    You need to have some weight on the ball joint. Thread the nut on a bit but leave it loose, then with a BFH hit the control arm as hard as you can.
  4. Jul 17, 2014 at 6:27 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks for the quick replies...
    Where should I hit on the upper control arm?
  5. Jul 17, 2014 at 6:30 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Right around the ball joint stud. Just be careful to not hit anything else.
    Side note, Oscar (User_Name01) mentioned the correct method. But the hammer usually works for those types of situations. (lower ball joint, outer tie rod end, etc)
  6. Jul 17, 2014 at 6:32 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Take a BFH and swing upward at the lip of the control arm. Should come out pretty easy, if it doesn't, hit it with some heat, than repeat.
  7. Jul 17, 2014 at 6:34 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks Brett, Is the bolt welded to the upper control arm?, or if not how is it held?
  8. Jul 17, 2014 at 6:34 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Only problem with heat is it may melt the ball joint boot. Kind of risky if you want to reuse it.
  9. Jul 17, 2014 at 6:35 PM
    Squeaky Penguin
    Brett
    That's your upper ball joint, which is press fit into the spindle from the bottom. What you're trying to do is seperate the ball joint from the UCA.
  10. Jul 17, 2014 at 6:39 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    So, is the balljoint attached the bolt?
  11. Jul 17, 2014 at 6:43 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Yes, the ball joint and the bolt are one and the same.
  12. Jul 17, 2014 at 6:49 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks, that cleared it up. Since i have tried laying on it with a 5lb sledge I think a balljoint separator is needed.
    Where do I place the the two jaws of the separator?
  13. Jul 17, 2014 at 6:51 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    Soak that thing with some penetrating oil.Grab your largest hammer in your box and smack the upper control arm near where the stud is.X marks the spot.If you have a friend around you can put a bar between the UCA and the arm the ball joint is on.The shock from smacking and the pressure from the prybar will cause it to break free.
  14. Jul 17, 2014 at 6:56 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks for your input.
    Will do. If / When it works I will follow up with the results.
    To All: Thanks for the asssistance
  15. Jul 17, 2014 at 10:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I found that no amount a smacking would dislodge ball joint from the UCA. I resorted to using one of these.
    Once I was able to get the three arms to grab, the BJ bolt pushed right out.
  16. Jul 17, 2014 at 10:18 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Wedge a 5' steel bar between the top of the spindle (the little shoulder that sticks out) and the upper control arm. Put some weight on the end of the bar and it should pop free. Thread the nut slightly on to keep it from coming out and possibly straining other parts.
  17. Jul 18, 2014 at 6:49 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    I talked to a local mechanic after failing to remove it with a large sledgehammer and he recommended I use a pickle fork...does this sound like a good idea?
  18. Jul 18, 2014 at 6:59 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
  19. Jul 18, 2014 at 7:18 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    It will probably ruin the ball joint. Old one would have to be pressed out of the spindle and a new one pressed in.
    Grab one of those pullers everyone has posted pics of.
  20. Jul 18, 2014 at 7:33 PM
    Squeaky Penguin
    Brett
    Pickle forks are great for removing ball joints. But agreed, will more than likely ruin the ball joint, well, at least the boot.
