Trouble Removing Bolt From Upper Control Arm With Pics
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deere9798, Jul 17, 2014.
  1. Jul 18, 2014 at 7:39 PM
    nate121080
    nate121080 Well-Known Member
    05 tacoma DC 4X4
    Use one of the pullers like above. I get as much tension on it as I can then I whack the control arm. Between the tension and shock it should only take a couple of whacks.
  2. Jul 18, 2014 at 7:40 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    Don't be a Sally hit the damn thing!
    seriously try soaking with Pen Oil put nut on until flush with top of bolt try and make a arm as solid as you can and hit a few times then come from underneath and hit as if osamas face was there.
    If you use a fork chances are high that damage will occur but I would use one of these, If you don't have one borrow one from an auto parts store just need to give credit card for security.
  3. Jul 19, 2014 at 5:37 AM
    Deere9798
    Deere9798 [OP] Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks for the input will continue to update as project moves along
  4. Jul 19, 2014 at 8:11 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    To conclude this thread I would like to say thanks
    to the members that left their advice.
    I ended up removing the balljoint with a pickle
    fork, this worked very well but as advised it ruined
    the boot/balljoint. This was not a problem because
    the balljoint is relatively inexpensive.
    Hope this thread will be of some use to people
    who are having the same issue.
    Thanks for the help.
    Charlie.
  5. Jul 19, 2014 at 8:36 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    New ball joints are cheap, but getting them pressed out/in is a pain in the ass. Haha
  6. Jul 19, 2014 at 11:09 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    1st gens......
  7. Jul 20, 2014 at 11:15 AM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Replaced my uppers yesterday. Easy peasy job. Took less than an hr.
    image by Tanner Tucker, on Flickr
  8. Jul 27, 2014 at 10:09 PM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    Removed mine with puller 3 piece . Used mallet and hit a arm. Left nut loose on top dropped loose ball joints tie rods are built so they pop loose my dad's a retired mechanic that'd how he always did it. It took some heavy hitting g but it works . I took my knuckle down to machine shop to have wheel bearings and seals replaced. Cost 75 bucks ks overall with bearing seals cv axles upper balljoints cost around 650 . Shop quoted me 1200 to do one side I did both for 1/4 of the price would of done a writeup with pictures but dont have the time been down for a month being able to pay for it all . I do all my own work except internal engine work. I don't trust myself in that field.
