Trouble removing driver side spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by lalojamesliz, Aug 13, 2018.
  1. Aug 13, 2018 at 7:21 PM
    lalojamesliz
    lalojamesliz [OP] Well-Known Member
    Ed
    02 dbl cab V6 pre-runner trd
    Tundra brake upgrade (in progress)
    I was trying to do a compression test with the engine at operating temp and the passenger plugs came out fine but the driver side plugs all had resistance. In fear of crossing the threads I just tightened them back up and left them alone.
    I just installed new dual prong denso plugs too. I didn't use antiseize but should I have?
    I've seen some people here say to use dielectric grease...... hmmm
    I've been wanting to get them out with the engine cold after a nights cool off but I still get worried.
    I really want to do a compression test. Runs good btw
  2. Aug 13, 2018 at 7:22 PM
    lalojamesliz
    Ed
    How long do new plugs usually last?
  3. Aug 13, 2018 at 7:46 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    How can you cross the threads when loosening? I thought crossing the threads happens when you start threading them in wrong at an angle then use a wrench. You should be able to screw them in almost all the way just using a socket and extension without the ratchet.
    For some plugs Denso will say do not use any anti-seize. Some plugs have plating on the threads which prevents them from seizing. Also, anti-seize will lubricate the threads and you can risk over tightening them.
  4. Aug 13, 2018 at 8:32 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    With stock NGK or Denso plugs you shouldn't need to use anti-seize. Dielectric grease is not used on the threads, it's used for the plug wire boots.
    If you were able to install them fine initially then they shouldn't be cross threaded. Unless the threads were already damaged prior to installing the spark plugs but you would have felt it when installing them. How far are you able to unscrew them? I know you probably can't see how much but roughly how much are you able to loosen them, like a few turns, more or less?
    BillsSR5 likes this.
  5. Aug 13, 2018 at 8:47 PM
    lalojamesliz
    Ed
    The old ones came out fine and the new ones screwed in perfectly fine. I messed up the threads on for 02 sensor removing it with a wrenches I've been paranoid since. Wrong tool I know.....
    I just dont understand why one side ( all 3) came out with no resistance but one side did
    I loosened 1 plug about 1/2 a turn before I gave up
  6. Aug 13, 2018 at 8:57 PM
    lalojamesliz
    Ed
    Right now the truck is sitting I'm my garage to cool overnight. That should be enough time to cool and I'll give it a try again.
  7. Aug 13, 2018 at 9:04 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Wow, 1/2 turn is like nothing. Only thing I can think of is that the threads stripped by overtightening or were compromised previously & finally gave out. But not likely for all 3 on one side, you'd have to crank down really hard to do that & I'm sure you would no better than that.
    Hope you get em out, definitely let us know what happens.
  8. Aug 13, 2018 at 9:08 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yup, never should try to take out plugs while the engine is hot. Should be close to ambient temp. Doing so is what causes threads to seize & very easily on aluminum heads. I hope that's not what he did. If that is what happened, sorry to say, but allowing it to fully cool is not going to solve the issue, damage is already done.
    Area51Runner and E30325 like this.
  9. Aug 13, 2018 at 9:10 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Damn I didn't know that. I did mine on a fairly warm motor. One of mine didn't wanna come out but I got it. Seemed fine though. Good to know
    Area51Runner and zero4[QUOTED] like this.
  10. Aug 13, 2018 at 9:14 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Fairly warm is a no no, slightly warm is not too bad but always play it safe & let it cool down especially on aluminum heads. Different types of metals expand & contract at different rates. Aluminum cools down faster than steel. The plugs are steel but with much less mass but still.
    Area51Runner and E30325[QUOTED] like this.
  11. Aug 13, 2018 at 9:23 PM
    Payback1974
    Payback1974 Member
    2002 tacoma double cab 4x4
    I had the same problem. Truck started running bad, hurried to friends house to pull the plugs and put new ones in and get home. The first two drivers side seized after 3 turns, i took it to a mechanic and the plugs broke off in the head.
    So i put in a new motor rather than rebuild the top end of a 370k mile one.
  12. Aug 13, 2018 at 9:32 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Didn't know that either. Definitely glad I happened across this thread since plug and wire change are on the top of the to-do list.
    zero4[QUOTED] and E30325[QUOTED] like this.
  13. Aug 13, 2018 at 9:42 PM
    lalojamesliz
    Ed
    I'm not disagreeing with anyone but aren't you supposed to remove the plugs on a normal operating temp engine to do a compression test?
    I love the activity on here! Lots of forums are dead on older topics like this
  14. Aug 13, 2018 at 9:55 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yes but not necessarily. I've always done compression tests with the engine cold, at it's worse case scenerio so to speak. Yes sealing will be better at operating temps but if you test cold & have good readings you know you are good. But in the case of aluminum heads, I wouldn't risk seizing the spark plugs. Plus with the engine hot, theoretically as the engine cools (probably not a big difference depending on how quick you are & if it's all iron) while doing the test you will get less accurate readings, depending on what you are testing to see.
  15. Aug 14, 2018 at 6:11 AM
    lalojamesliz
    Ed
    I was tired from work but the 3 driver side plugs just came out without any problems so I'm pumped enough to pull the other ones and do the compression test with a cold engine. Its 91 degrees in my garage
    Winner winner chicken dinner :D
    Two of them are 185 and the rest are 190 :thumbsup:
    Thanks for your help guys!
    Area51Runner likes this.
  16. Aug 14, 2018 at 7:16 AM
    lalojamesliz
    Ed
    I have taken off a head from a 22-r then gave it a valve job and had it machined for the HG then did a timing chain job and got it running again.
    I have taken out the engine from my other toy, removed the head and did the same but I also replaced everything that goes with a timing belt job and a clutch job on my awd celica all-trac with a 3sgte.
    Stripping a spark plug thread in this V6 scares some poop out of me.....:oops:
  17. Aug 14, 2018 at 9:58 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    With a compression test all you're looking for is a difference from cylinder to cylinder. Cold is fine, as all things are equal with each cylinder. I always use antiseize with dissimilar metals, with plugs especially given their operating environment. It doesn't need a lot. Risk of over torquing is mitigated using a torque wrench.
