Trouble removing front shock strut (help)
Discussion in '1st Gen. Tacomas (1995-2004)' started by hwkellogg, Oct 26, 2014.
  1. Oct 26, 2014 at 10:13 AM
    hwkellogg
    hwkellogg [OP] New Member
    Montana
    '02 TRD SR5
    Hello all,
    I am new here but have been following for some time.
    I recently acquired a 2002 Tacoma TRD SR5 Auto V6 with 4x4 yadda yadda yadda.
    All my shocks are shot so I decided to purchase some new blue and yellow billsteins.
    I did my research on here and watch numerous videos of the non spring compressor method (lowering the LCA with a jack.)
    I have jacked up my LCA, loosened the LCA where it attached to the body, removed the top nut from the shock. Removed the castle nut from the Ball joint, removed the two bolts from the dust cover on the ball joint (dumb mistake). I have then have tried to slowly let me jack out and lower my LCA. I was under the impression that my ball joint would completly come off my steering knuckle and allow my LCA drop all the way out of the way. photo (1).jpg
    Here is where I have things. When I let my LCA down the ball joint does not come off and let everything drop. I just want to be absolutly sure there is no pressure on the spring before I attempt the lower shock mount!!!
    Any ideas here? I really hope I can get this done today and drive it to a shop on monday for an aligment.
    I was thinking it probably is just stuck in place from age. I was gonna run the castly nut back on but leave it a few threads loose. I was gonna then put my jack underneath and give it a tiny bit of room and give the stud from the ball joint a couple taps to try and convince it to let loose.
    Any reason I wouldn't want to do it that way or how I should remedy this situation.
    Thanks in advance for all the advice.
  2. Oct 26, 2014 at 10:45 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Kinda hard to follow for your description and I have never swapped COs using this method but if you are trying to separate the ball joint from the spindle, the ball joint is attached to the spindle by 4 bolts not 2.
  3. Oct 26, 2014 at 10:53 AM
    JohnB81
    JohnB81 Well-Known Member
    OC
    2018 Tacoma TRD Sport 4x4 DCSB
    trifold solid bed cover (Amazon) Pop & Lock tailgate auto lock LED Headlight/ fog lights, reverse lights, dome/plate lights AVS ventshades Smartliner front & rear floor mats Rough Country neoprene seat covers BHLM NiLight LED strip bed lights NiLight RGB LED strip lights behind rear seat storage NiLight RGB LED strip lights for under hood and behind the grill lighting NAVIKS Apple CarPlay interface on stock Entune system Auxbeam auxiliary fuse box/ switch controller Auxbeam custom fit switch panel (Etsy) Coin holder bucket (Etsy) Center console organizer HookeRoad center console vault 32” Slim LED light bar mounted on CaliRaised Offroad lower bumper brackets Suparee sequential turn signals in black smoke OEM bed mat Sokie Tech hood struts 14” Hood scoop LED light bar RGB Raptor lights with smoked lens K&N air filter with TRD air intake accelerator K&N cabin air filter ViAir portable air compressor TuffSkinz interior red color accents on doors and center console TRD faux Pro shift knob w/ TVD TRD decal Glove box letters from Tacos4Cheap MESO customs chrome delete MESO customs door handle blackout covers MESO customs minimalist key fob V1 & V2, red MESO buttons MESO customs puddle lights MESO customs dual color map lights Matte black steering wheel overlay TVD matte black glove box overlay Pedal Commander A/C drain mod Red/Black paracord grab handles Red seat pull straps LOSTAR faux Pro skid plate Rockville 8” powered subwoofer CaliRaised LED catalytic converter plates Hooke Road tailgate panel Rok-Block tailgate gap seal Rear cab USB mod (idea from @ClassyTacos) Xprite RGB rock lights Falken Wildpeak MT 285/70/R17 Painted calipers red w/ TRD decal Akebono brake pads eBay seat jackers 4WP rock sliders DS18 tweeters DS18 front speakers Bought it with: Black Rhino Hammer wheels Spacer lift 285/75/17 Toyo MT’s TRD Pro Grill Hertz Audio speakers/ KENWOOD tweeters
  4. Oct 26, 2014 at 10:55 AM
    JohnB81
    OC
    This method is foe 2005+ so it may be slightly different on your 2002. Kinda jumped on the reply quickly
  5. Oct 26, 2014 at 10:58 AM
    hwkellogg
    Montana
    '02 TRD SR5
    :confused:
    Ok, I've watched that video a couple times. Should have listened. Figured the castle but would be a one stop shop! I on a 1st gen so I should have to remove all 4 correct? They are freakin tight and access is kinda crappy gonna go get a breaker bar and hope that works!
  6. Oct 26, 2014 at 12:59 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Make sure the jack is secured up under the lower control arm and applying pressure to the spring. The trucks front-end will want to lift up when adequate pressure is applied. Remove the nut holding top shock rod.
    2 ways you can do it.
    1. You can do it by removing the castle nut and hammering sharply (A few good hard solid hits) on the SIDE (textured iron part) of the ball joint assembly closest to the ball joint pin to break it loose. (Pin is what the castle nut goes on ). The vibrations from hammering will break the tension between the pin and the iron housing. The pin will loosen itself when the tension is broke. You will be able to lift the spindle up and down also fairly easy. DO NOT HAMMER ON THE PIN ITSELF.
    OR
    Loosening the 4 bolts holding the lower ball joint assembly to lower control arm.
    Those 4 upside down bolts have BLUE loctite on them to keep them from working loose. So they are going to be tight. You should put blue loctite BACK ON THEM after cleaning the bolts with a wire brush to remove all the old locktite. They must be clean before they go back in with fresh loctite.
    If you have ABS brakes, You will want to unbolt the wire from the spindle.
    Once you have separated the ball joint assembly ( by either method above ) from the lower control arm SLOWLY lower the jack. The spring and shock should fall down enough to pull the spring and shock out. May have to remove sway bar linkage.
    Be very very careful.
  7. Oct 26, 2014 at 1:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Welcome to TW, Ok you've probably already figured out you didn't need to take the castle nut off, just the 4 bolts that hold the LBJ to the spindle, when thats done then you can start lowering your jack, be sure to watch the spindle, when it seperates from the LBJ it's probably going to swing out on you.. With the LCA drooping down theres enough free movement in the UCA to pry up & slide strut/coil assembly out of the coil bucket & make sure you've taken the strut nut all the way off (ya kinda have to, to disassemble) I've done many struts/coils this way...
  8. Oct 26, 2014 at 1:31 PM
    hwkellogg
    Montana
    '02 TRD SR5
    Awesome Guys! This all helped alot. I now have the strut and coil out and the new one ready to go. My newest problem is I can not get my LCA low enough to get the lower mount of the new shock attached.
    I have removed my sway bar linkage, but do I also need to remove the remove the bar connected to the steering rack? It seems like that is the only thing I'm still fighting when trying to get my LCA lowenough (sorry about the poor terminology, I'm an aircraft mechanic by day and just don't have to deal with drive trains too often!)
    ( I dunno why the forum keeps uploading my photos sideways)
  9. Oct 26, 2014 at 1:35 PM
    hwkellogg
    Montana
    '02 TRD SR5
    & Thanks for the welcome. Always nice to join the community!
  10. Nov 28, 2014 at 6:08 PM
    acolsch
    acolsch Member
    Andy
    McGuire AFB, NJ
    05 Tacoma
    DVD Player
    HwKellogg,
    The truck is in the garage, with the same problem you state. The LCA will not fall low enough to put the low strut pin in. On all the videos they are showing the 2005+ taco and I can see the LCA fall away.
    I have loosened the LCA alignment bolts, but not removed. I also disconnected the sway bar. Still pushing down on the LCA and get resistance before it goes low enough.
    Did you figure it out???
    Andy
  11. Nov 28, 2014 at 6:14 PM
    acolsch
    acolsch Member
    Andy
    McGuire AFB, NJ
    05 Tacoma
    DVD Player
    By the way, The profile pic is the wife's Tacoma. Mine is a 2004 TRD.
  12. Nov 28, 2014 at 6:58 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    that is your tie rod, if its holding you up you can disconnect it from the ball joint. Remove the castle nut holding the pin into the ball joint then take a hammer and wack the side of the part of the ball joint that the pin goes through a few times and it should pop out. Does that make sense? Don't wack the pin itself but the cast part of the bj the pin goes through. Also it might be a good idea to leave the castle nut on the last few thread while doing this in case you miss and hit the pin by mistake so you don't bugger up the threads. It might be a good idea to temperarely bolt the balljoint back to the knucle while doing this so its more solid when you wack it.
  13. Nov 29, 2014 at 12:04 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It might sound a bit brutish but I got my 3.0in of lift struts in by just using a huge pry bar and lowering the LCA by force, and i never disconnected the spindle from the LCA in any way.
  14. Nov 29, 2014 at 12:18 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Standing on the hub works too. :p
  15. Nov 29, 2014 at 5:13 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    OP, for the tie rod end invest in one of these:
    The cheapest ones are $10-15 at the local auto parts store and will work perfectly on the tie rod end - popping it out in seconds.
    Alternatively, you can hammer the living fuck out of the metal side of the hub assembly that the stud of the tie rod end goes through, eventually that will pop the tie rod out. Just dont use a pickle fork on it unless you are going to be replacing the tie rod end.
  16. Nov 29, 2014 at 7:11 PM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    ^^ Moco - I think that tool needs to be modded slightly to fit. I bought that and it won't fit around the assembly. I think you need to trim a little off the arms, right? Mine is a 97 4WD 2.7L.
  17. Nov 29, 2014 at 7:14 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I use the smaller version but it is my understanding the larger one works fine as is.
  18. Nov 29, 2014 at 7:18 PM
    97TacoNM
    Jim
    NM
    I'll have to triple check mine - seems like I tried twice now and it would not fit. If not, I will post pics/vid of that. I may pick up a set at Harbor Freight - they have a pack of three differing sized 3 arm pullers. They only need to work a few times, so if cheap, well not a problem if they do the job!
  19. Nov 29, 2014 at 7:39 PM
    tomtom
    The Desert SW
    2012 FJ
    I put some torque on it then give the knuckle a gentle rap with a hammer if it didn't come apart with the torque alone. Usually pops in one pop. So far, no signs of stress on the pullers.
    I do know that the OTRE requires some attention to the angle of the tool to get it on there right.
  20. Nov 29, 2014 at 9:24 PM
    Moco
    Eric
    NoVA
    You shouldnt. I picked up the cheapest one (the tool) at AdvanceAuto (Autocraft brand) and that son of a bitch popped out my tied rod end and my ball joint with 0 issues. It fit perfect with no modification necessary. These tools generally come in a large and small. The small one worked for me with no issues on my 96 2.7L 4x4.
