Trouble removing headlamp housing covers '00 Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by jjwstaco, Jan 31, 2010.
  1. Jan 31, 2010 at 3:19 PM
    jjwstaco
    jjwstaco [OP] New Member
    James
    Santa Fe, NM
    2000 Tacoma 4cyl 2.7L 4x4
    Leer 122 Shell 4" Toytec Ultimate Lift, Adjustable front coilovers w/ Bilstein 5100s, 2" OME Dakar Leafs w/ Bilstein 5125s, Light Racing UCAs ARB Bull Bar with Warn M8000 Winch and 2 Warn 650D wireless Halogens
    When I bought my 2000 Taco a few months ago I couldn't help being annoyed by the grungy build up inside the headlights.
    Today I had a crack at removing the covers. I tried just removing the clips around the cover- no luck (glued on? Vacuum Sealed?) so I looked through the Haynes manual and tried removing the entire housing. I did everything by the book, removed the grill also, but after removing all of the bolts and the indicator housing I still could not remove the housing.
    I'm not sure what to do- this isn't an issue I want to pay a mechanic to solve. I figured I could take care of this myself. Does anyone have any suggestions?
    Thanks
  2. Jan 31, 2010 at 7:37 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i know this sounds sketchy but put then in the oven at 200* and leave them for 8 mins and then when there done take them out and slowly pry them appart
    thats how i took mine appart
  3. Jan 31, 2010 at 7:50 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    ^That might be too cool, makes it a little harder haha
    Ive found 225* for 14min works great... I put lights in the oven everyday :)
  4. Jan 31, 2010 at 8:05 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    ^ might be better
  5. Jan 31, 2010 at 8:24 PM
    dually
    dually Low and slow
    ^Did you have any difficulty at that temp?
  6. Feb 1, 2010 at 5:30 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    ^not really but it was harder to pry them appart
    i was scared enough to leave them in there for that long :eek:
  7. Feb 1, 2010 at 7:25 AM
    dually
    dually Low and slow
    ^ haha, we usually cook lights at 225-250 for upwards of 16min at a crack!
  8. Feb 5, 2010 at 1:27 PM
    jjwstaco
    James
    Santa Fe, NM
    Before I can even think of putting them in the oven---- I have to get the housings out of the truck.. I took off the grill- unbolted all of the bolts and pulled! They barely move- any suggestions? Those little plastic pieces are tough. I already busted one removing the side indicator housing-
    Thanks for the info thus far- much appreciated
  9. Feb 6, 2010 at 6:42 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    are ya sure the buildup is on the inside? I thought i was going to have to do something similar to what your doing to clean em, but decided to try some maguires headlight cleaner. Cleaned it right up,no more yellow bullshit on it.
  10. Feb 6, 2010 at 8:46 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    are you sure u removed all of the bolts?
    there are 2 nuts that attach from the side behind the corner marker and one on the inside top behind the grill and there is one behind the filler peice under the headlight (you have to remove the filler piece to get to it)
    io beleve thats it?
    and there all 10mm
  11. Feb 7, 2010 at 5:07 AM
    dually
    dually Low and slow
    yeah pop off the corner lights fo sho.
