Trouble removing tail light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by andrewkissam, May 16, 2025.
  1. May 16, 2025 at 10:22 AM
    andrewkissam
    andrewkissam [OP] Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    Posted this in the lighting forum but not getting any replies, thought I'd try here...
    2017 Tacoma owner here. I had a tail light burn out and cannot for the life of me get the bulb assembly out of the housing. It's the 7443 style bulb. I'm not talking about the bulb itself, but rather the sub assembly that the bulb clicks into which then twists into the tail light housing with the bayonet style coupling. That entire sub assembly will not untwist. If that makes sense. It's supposed to be a partial counterclockwise turn and then the fitting comes free from the housing. I'm able to turn the fitting, and it feels loose but it won't come out of the housing almost like it's getting hung up on something. All the other tail light fittings I can untwist with no problem to get to the actual bulb, but I'm just having trouble with one of them.
    Anyone experience this before? Any suggestions?
  2. May 16, 2025 at 11:28 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I’d say try brute force! I’d wiggle that puppy like it was caught in a tornado.
  3. May 16, 2025 at 11:33 AM
    andrewkissam
    Dallas, Texas
    Tried that. I honestly feel like I'm gonna break it if I pull any harder. Maybe I should just say F it and try yanking it out with a pair of pliers. If it breaks then perfect excuse to buy some cool aftermarket lights lol
    Captqc[QUOTED] likes this.
  4. May 16, 2025 at 11:38 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
  5. May 16, 2025 at 12:21 PM
    Captqc
    Tigard, OR
    How about some soapy water or WD 40?
  6. May 16, 2025 at 12:21 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    You said it'll turn... Maybe try to pry it out with two large flat screwdrivers?
  7. May 16, 2025 at 2:23 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You say it will turn counterclockwise ? Maybe you haven't turned it far enough and it's catching in the edges because it's not fully turned or ready to pull cleanly. Put on a work glove and give a good turn. If you turn it as far as it will go it should almost fall out.
  8. May 29, 2025 at 11:10 PM
    Archie boy
    Archie boy Well-Known Member
    Archie
    Santa Cruz
    2020 Tacoma TRD OffRoad 6footie
    Gfc, eibach suspension, Rrw wheels, prinsu roof rack,
    When you turn it it should make kinda click sound. Sounds like you might need to turn it more
