Trouble removing wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomich, Nov 24, 2022.
  1. Nov 24, 2022 at 5:09 AM
    tacomich
    tacomich [OP] Active Member
    2021 Tacoma TRD OR
    Almost feel dumb posting this, but kind of at a loss for wtf I'm not seeing...
    I picked up some road debris in the side wall of my driver's side rear, on my 21 OR. I loosened the 6 lugs, jacked up the left rear, finished removing the 6 lugs... and the wheel won't come off. The truck has ~18k miles, and just had the tires rotated 3k miles ago via the Toyota care service. I was kicking the wheel hard enough I was worried about the truck sliding off the jack, I don't think it was just hanging on with rust and road grime.
    What am I missing? Is there something else I'm not seeing attaching these wheels to these trucks?
  2. Nov 24, 2022 at 5:13 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’d put the lug nuts back on loosened two turns. Put the truck in reverse, turn the wheel left hit the throttle then slam on the brakes to pop that Bitch
    RIX TUX and wilcam47 like this.
  3. Nov 24, 2022 at 5:15 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Its rust around the center part of the rim. Its a pain to get off sometimes
  4. Nov 24, 2022 at 5:18 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    It's usually rust/corrosion (even after just a few weeks) that kinda 'welds' the wheel to the hub. It often helps to apply a generous coat of anti-seize or a good corrosion resistant grease on all contact surfaces between the hub & wheel.
  5. Nov 24, 2022 at 5:31 AM
    xndak
    xndak Well-Known Member
    2023 Off Road
    Its rust and road grime - Google it for options
    wilcam47 likes this.
  6. Nov 24, 2022 at 5:45 AM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    Dumb question, but the parking brake is released, yes?
  7. Nov 24, 2022 at 6:00 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Pretty common with aluminum wheels. My kicking days are past...
    Usually you can get a 2x4 or a bar on the back side and pry against the rim and brake drum, if you use a bar tape up the end and be careful not to scratch the wheel.
    Option 2 is to loosen the lug nuts a turn or two and drive slowly around the block, they will usually pop loose when taking a corner.
    Wire brush the hub where the wheel mounts and also clean up the wheel. Apply a skim of anti-seize or grease to all surfaces to prevent future issues.
  8. Nov 24, 2022 at 6:01 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Is the tire still drivable? If so Id take it back to the dealer and have them take the tire off. If the tire is flat, use a sledge hammer on the inside of the tire.
  9. Nov 24, 2022 at 6:02 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Make sure you are kicking the tire as far away from the hub as possible. I always had the best luck by kicking the top, or using a dead blow or sledge. Please chock the wheels and put it on jack stands...
  10. Nov 24, 2022 at 6:02 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Jack it up, loosed the lug nuts about 3 threads, back up to the tire and mule kick the rubber part a few times, it will break loose after a few kicks
    thomasburk and wilcam47 like this.
  11. Nov 24, 2022 at 6:38 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    You can try loosening lug nuts to snug no real torque, drive it around the block slowly couple of turns at slow speed. That should do it.
  12. Nov 24, 2022 at 6:44 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You can also loosen lugs a few turns. Set truck back down on ground, shake truck side to side. This will pop wheel loose.
    RIX TUX, eurowner, thomasburk and 2 others like this.
  13. Nov 24, 2022 at 6:51 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    It's totaled, better trade it in
  14. Nov 24, 2022 at 7:03 AM
    tacomich
    2021 Tacoma TRD OR
    Thanks for all the replies and laughs. Made me feel better. Gonna give it another go after some family time. Happy Thanksgiving fellas.
    RustyGreen and Steves104x4 like this.
  15. Nov 24, 2022 at 7:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    He's trying to remove the wheel/tire, not the brake drum.
  16. Nov 24, 2022 at 7:18 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Take the lug nuts off, smack the tire in various outer spots with a large dead blow hammer.
    vicali likes this.
  17. Nov 24, 2022 at 7:24 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  18. Nov 24, 2022 at 7:28 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    Yup, let the truck do the work. Usually when lugs are loosened, and once the wheel hits the ground it should pop loose pretty quick, like right away.
  19. Nov 24, 2022 at 7:40 AM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    Hah, you're right...brain fog.
  20. Nov 24, 2022 at 7:50 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I’ve had success with this method as well. Scares me less than driving on it.
    eurowner and na8rboy[QUOTED] like this.
