Trouble running in sand 4H
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LiveFreeOrDie2015, Nov 25, 2017.
  1. Nov 25, 2017 at 4:16 PM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 [OP] Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I was out surf fishing today and my truck was dropping down RPMs bringing me almost to a stop. The beach was deep loose sand but never had any problems running this beach before.
    At low speed 5-10mph everything was fine. As speed increased to 15-20 mph truck was cutting power and sounded like A-trac was on. Driving in 4H I tried turning of traction control but it didn't make a difference.
    What are the best setting to run in loose sand? (Not looking run Baja but some beach entrances you need speed to get over)
    No dash lights came on during the rpm drop
  2. Nov 25, 2017 at 4:22 PM
    glock24
    glock24 Well-Known Member
    I like 4LO in sand, myself. Why not? Especially if you're only going 15-20 mph
  3. Nov 25, 2017 at 4:32 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Yes at that speed 4L would be fine. I am just surprised how the truck was acting and not being able to build speed. Power would drop if I got around 3,000 rpms.
    How do people run High speed sand dunes if the truck nannies you at 20mph?
    Just looking for advice for mid speed sand travel. Like I said never have any problems at 5-10 mph. I don't air down to drive on the beaches so that doesn't help things but still doesn't explain way I can build speed.
  4. Nov 25, 2017 at 4:35 PM
    eon_blue
    Azusa, CA
    Should definitley air down, 15 psi or so in sand will give you much more traction and you won't need to floor it as much to keep momentum. Spinning tires with little to no traction will slow you down big time. Your tires aren't grabbing much with all the throttle you're giving it and you aren't able to gain or keep momentum.
    Jimmyboyblue and 12TRDTacoma like this.
  5. Nov 25, 2017 at 4:40 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Not disputing that fact at all. Just lazy :anonymous:
    Guess my question is way my truck was dropping power to the wheels. A-Trac is 4L only and traction control was off when in 4H
  6. Nov 25, 2017 at 4:45 PM
    eon_blue
    Azusa, CA
    Unless there's some feature I'm not aware of that's actually cutting power, I don't think that's the issue...I think it just seems that way because you aren't getting traction for all the throttle you're applying so your bogging down despite high RPMs. I've had the same thing happen to me when trying to climb a steep, loose dirt hill in 4hi...the truck wants to practically stall out. That's why you want to crawl in 4lo in that particular situation but for maintaining high speed in level sand terrain you need traction at the wheels...good tires and airing down are the ticket.
  7. Nov 25, 2017 at 4:56 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Yes the truck was "clicking" like traction control was cutting in or A-trac was on but no lights on dash would activate during the reduction in speed and rpms.
  8. Nov 25, 2017 at 4:59 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Can't you turn off the nannies? Hold the button down for 3, seconds, hold it down for another 3 seconds and press it one more time...At least this is how it works on my 2nd gen Tundra.
  9. Nov 25, 2017 at 5:07 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I held the button for 3 seconds but that was it. I was under the impression that's how 2gen tacomas are.
    Even is trac was activating no dash lights came on showing:burnrubber:
  10. Nov 25, 2017 at 5:12 PM
    koditten
    Kirk
    Central Michigan
    I don't have anything else to offer, since I have the Tundra and that's how mine works.
    I learned fast after I got stuck in my back yard and the wife pulled me out with her 4 cylinder 1st gen 4 x 4. It took a while before I heard the end of that one. She didn't even spin a single tire.
  11. Nov 25, 2017 at 5:19 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    No worries, Thanks for the information
    I'm just trying to see if anyone else has had this problem running loose sand and what setting they found to work best.
    I mainly what to know how to keep wheel spin without the truck reducing power to the wheels. Is it normal not to have dash light come on if traction control is activated.
  12. Nov 25, 2017 at 5:19 PM
    koditten
    Kirk
    Central Michigan
    Yes, the lights will turn on when wheel slip is detected.
  13. Nov 25, 2017 at 5:57 PM
    Pigpen
    Dan
    Northwest Montana
    Wheel spin digs you in. Downshift and run slower.
    With that said, it sounds like the traction control was limiting power to try to gain traction. I've had this occur with no lights on icy roads.
    DanoDavis likes this.
  14. Nov 25, 2017 at 8:16 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Yeah it's hard to explain the driving style in the sand. Speed was increasing and was running a nice pace. I could definitely feel some wheel spin but this was like hitting the brakes and coming to a crawl.
    Picture driving up a long snow covered hill knowing that your tires will be slipping but you are still building speed and momentum. Then you are almost at the top and the truck brings you to a crawl when all you needed was to keep momentum.
    I'm sure this truck is more capable than my Offroad driving skills and love having all the features but I drove rear wheels drive service vans in horrible snow/ice conditions and never doubted getting to my destination. To the point where it was fun playing in the snow.
    Just didn't know if I'm using all the bells and whistles correctly or if there is a way to dumb down the controls so the driver can just drive.
  15. Nov 25, 2017 at 8:25 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Putting the truck in 4lo will turn off traction control which is what your experiencing, or just turn off the trac.
  16. Nov 25, 2017 at 8:30 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I tried with Trac and without. All you do is hold button for 3 seconds correct? Truck was running the same no matter if trac was on or off
    Side note what is a safe top speed for 4L?
  17. Nov 25, 2017 at 8:35 PM
    mlcc
    Oregon
    It will say trac off, I think press button once and hold for 3 sec but dont quote me, and 25 mph is pretty much top speed in for 4lo.
  18. Nov 25, 2017 at 8:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Air down in sand! EVERY TIME!
  19. Nov 25, 2017 at 8:43 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Even with going through the TRAC off procedure, I think it is still running in the background and will still kick in, it's just not as sensitive as when it's fully on.
  20. Nov 25, 2017 at 8:44 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You need a lot of hp , and tires capable of keeping you on top of it . the moment you slowdown your tires dig in and you're done
