trouble shifting gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by ground beef, Feb 2, 2020.
  1. Feb 2, 2020 at 6:16 AM
    ground beef
    ground beef [OP] Member
    Braeden
    Western MA
    2001 4cyl RWD
    howdy folks,
    I'm having trouble shifting into 1st and R (sticky shift). In addition, my 3rd gear occasionally slips into neutral but the shifter stays in 3rd gear position. I bought the truck used a few weeks ago and haven't had a mechanic look at it yet, but the seller told me that the clutch was replaced last week. This is my first standard and I've been a bit rough on it teaching myself. Any thoughts as to what may be causing this? Thanks!
  2. Feb 2, 2020 at 6:34 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Have a look at the clutch linkage under the dash for worn/loose parts they should be very little play. If it's all OK bleed the clutch hydraulics.
  3. Feb 2, 2020 at 7:11 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Shifter bushing and seat is a cheap, easy fix
    @ground beef
    Kiloyard likes this.
  4. Feb 2, 2020 at 7:19 AM
    ground beef
    Braeden
    Western MA
    2001 4cyl RWD
    Thanks @maineah & @Black DOG Lila , I'll see if I can take this one on myself then! Not very mechanically savvy.... yet ;)
  5. Feb 2, 2020 at 7:33 AM
    Wulf
    rock raisin
    Black DOG Lila likes this.
  6. Feb 2, 2020 at 7:36 AM
    Black DOG Lila
    Virginia
    Fluid in clutch reservoir should be clear, if it's discolored use a turkey baster to remove the old fluid in lieu of bleeding. Careful with the fluid as it can dissolve paint. DOT 3-4 brake fluid is used by clutch and brakes. @ground beef
  7. Feb 2, 2020 at 7:46 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Agreed. This solved my shifting problems, including the "popping out of gear" issue. You can also just buy a new rubber bushing, but they break down.
  8. Feb 2, 2020 at 11:48 AM
    ground beef
    Braeden
    Western MA
    2001 4cyl RWD
    Thank you @Wulf & @Kiloyard for the additional input. I'll update this thread with progress made on the issue
    Wulf likes this.
  9. Feb 2, 2020 at 11:52 AM
    Wulf
    rock raisin
    Good luck. These transmissions are pretty long lasting so I doubt there are any permanent issues.
    At 208k mi changing to redline in the transmission made my shifts so much less clunky.
  10. Feb 2, 2020 at 3:15 PM
    ground beef
    Braeden
    Western MA
    2001 4cyl RWD
    So, the guy at auto zone thinks I’m being too gentle with the shifter... I ended up leaving with coolant and a 1st gen. repair manual... Doh!
  11. Feb 2, 2020 at 3:34 PM
    Black DOG Lila
    Virginia
    You'll find plenty of members here willing to share their combined experience with Tacomas. When the counter jockey at the local parts chain store isn't helpful TacomaWorld to the rescue!
    @ground beef
