Trouble Shifting into Reverse
Discussion in '4 Cylinder' started by Juggernaut, May 18, 2012.
  1. May 18, 2012 at 10:56 AM
    Juggernaut
    Juggernaut [OP] Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Sometimes (lets say 15% of the time) I will not be able to shift my truck into reverse. No matter how hard I try to force the gear lever into R, it will not go. I have to roll forward about an inch, than it will pop into R.
    Is this normal? Can it be fixed? It is a little frustrating.
  2. May 18, 2012 at 12:36 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mine does the same. With the clutch in, shift into first before moving into reverse. Sometimes youll have go 1st, 2nd, then R to get the teeth out of alignment.
  3. May 18, 2012 at 1:34 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Mine has done it with first before. It just won't go. Sucks when traffic is waiting behind you. I usually drop it to second and back up. Don't know the mechanics behind it though. . .
  4. May 18, 2012 at 4:09 PM
    Juggernaut
    Sacramento
    I guess it's not broken, just poorly engineered.
  5. May 18, 2012 at 5:48 PM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    Let clutch pedal out, then in again and R. Jiggle shifter while doin it. It's allways worked for me.
  6. May 18, 2012 at 6:11 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup... every now and then my '94 would give me problems going in.. normally reverse, sometimes 1st.
    Neutral, slip the clutch, then pop it right in.
    Pretty freely spinning trans too... if I hit the shifter too quickly after pushing the clutch back in it would still grind.
  7. May 18, 2012 at 6:23 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what works for me is putting it in first then going to reverse if you have a hard time getting into R
  8. May 19, 2012 at 4:00 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    Works every time!
  9. May 21, 2012 at 7:30 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Normal, I have yet to drive a manual transmission that does not do that.
  10. May 21, 2012 at 6:12 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    this.
  11. May 21, 2012 at 7:47 PM
    Juggernaut
    Sacramento
    ^ Iv'e done that, doesn't work. I guess I will live with it as it appears to be normal. Iv'e only had one other stick and it never had this problem. O well.
  12. Dec 18, 2012 at 2:38 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Pump the clutch!
  13. Dec 18, 2012 at 8:17 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    mine does it more if I park without the emergency brake engaged. rarely happens when i use the parking brake.
  14. Feb 14, 2013 at 2:27 PM
    3INVERTED9S
    3INVERTED9S Well-Known Member
    Los Angeles, CA and Rio Rancho, NM
    2011 Tacoma 4X4 reg cab manual 4cyl.
    Method Standard wheels, Good Year Duratracs, Tint, K&N air and cabin filter, EBC Rotors and pads, Shitty JVC head unit, all Redline fluids, Optima battery, Bilstein 5100s, Uniden 520XL
    I've had 3 manual trans Toyotas and all of them did this. Come to a complete stop, shift into 2nd then reverse.
  15. Feb 14, 2013 at 2:41 PM
    koch1024
    koch1024 Well-Known Member
    Andy
    NYC
    04 Xtra Cab 3.4 5spd
    Icon 2.5s with Camburg UCA's, 5100s in the rear, K&N intake, Borla cat back,
    x2. Sometimes the gears aren't lined up right.
