Trouble sighting rifle, need help!!
Discussion in 'Guns & Hunting' started by Sigi, Sep 3, 2017.
  1. Sep 3, 2017 at 7:16 PM
    Sigi
    Sigi [OP] Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    IMG_0085.jpg I just bought a new browning x-bolt hells canyon speed in 300 WSM. I mounted a new Swavroski Z5 3.5-18x44. I tried to sight my rifle today and could not get a tight group. My mounts and scope were tightened with loc tight. I am also shooting off a Caldwell shooting test. I would appreciate any help. Above was my group at 100 yards!
  2. Sep 3, 2017 at 7:19 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Which kind of shooting rest, does it support the rifle at the front and rear? Are you used to shooting rifles with a decent amount of recoil and not flinching or jerking anticipating the recoil? Basic fundamentals are sound and you've had nice tight groups with other rifles? Have you tried more than one type of ammo?
    Thaitoy and Sigi[OP] like this.
  3. Sep 3, 2017 at 7:19 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    What's your process and experience?
  4. Sep 3, 2017 at 7:24 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    So to be clear these are four shots and no adjustments made? (I see stickers cover other shots) What ammo are you using? Are you a left handed or right shooter? How is your trigger control?
  5. Sep 3, 2017 at 7:33 PM
    Sigi
    Sigi
    Sfv ca
    It supports the front and rear, I know I'm not flinching, and yes I have another hunting (270 WSM) rifle that shoots tight groups. I've only tried one kind of ammo. Can it be the bullet weight ? Could it be the Im just letting the rifle just sit on the shooting rest with out putting any time of pressure on it ?
  6. Sep 3, 2017 at 7:37 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Is your scope crosshair level to the rifle scope base?
  7. Sep 3, 2017 at 7:43 PM
    Sigi
    Sigi
    Sfv ca
    I've been shooting and hunting for over 20 years.
  8. Sep 3, 2017 at 7:55 PM
    Sigi
    Sigi
    Sfv ca
    Yes, I bought a leveling kit and leveled it.
  9. Sep 3, 2017 at 7:59 PM
    Sigi
    Sigi
    Sfv ca
    Yes it was 4 shoots with my adjustment . I am a right handed shooter. I think I have pretty decent trigger control. I've had lots of firearm training and certifications, through my work.
  10. Sep 3, 2017 at 8:00 PM
    Sigi
    Sigi
    Sfv ca
    Could it be a that I leave the rifle just laying on the rest and don't hold it when I shoot? And no weights on my shooting rest.
  11. Sep 3, 2017 at 8:02 PM
    Sigi
    Sigi
    Sfv ca
    image.jpg This is my shooting rest.
  12. Sep 3, 2017 at 8:05 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    When I've used those type of rests that cradle the front and back of the rifle I still try to hold the rifle with the same firmness I would without the rest, otherwise the rifle is free to shift with the recoil when fired and can give unpredictable results. Maybe give that a shot and see if it improves the grouping before buying another box of ammo.
    hoverlover and Radarninja like this.
  13. Sep 3, 2017 at 8:05 PM
    Radarninja
    Northern California
    06 taco
    Yes we need to be sure there are no positional changes after each shot.
    Bullet weight and barrel twist do play a role however your group is wide for that at only 100 yd. improve your rest set up with sand bags. Other than that try another Weight, try another brand. That is a very capable long range flat shooting round.
  14. Sep 3, 2017 at 8:06 PM
    Sigi
    Sigi
    Sfv ca
    This is the rifle.
    scottalot and Radarninja like this.
  15. Sep 3, 2017 at 8:07 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Shoulder the butt of the rest as if it were the rifle's butt and position your supporting hand underneath like normal and apply rearward pressure, pulling the butt into your shoulder.
    Radarninja likes this.
  16. Sep 3, 2017 at 8:07 PM
    Radarninja
    Northern California
    06 taco
    She's a beauty. Barrel length?
  17. Sep 3, 2017 at 8:08 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Make sure there is no pressure on the barrel by the forend of the stock. I have a Browning and had to get a gunsmith float the barrel. It was touching the forend of stock at the end.
    NM Lance and Captqc like this.
  18. Sep 3, 2017 at 8:09 PM
    Sigi
    Sigi
    Sfv ca
    Yes I was thinking that might be the problem because the rifle moves a lot after every shot without me holding it down.
  19. Sep 3, 2017 at 8:09 PM
    Sigi
    Sigi
    Sfv ca
    Thanks ! It's a 23" barrel.
  20. Sep 3, 2017 at 8:10 PM
    Sigi
    Sigi
    Sfv ca
    No I'm not putting pressure at all.
