Trouble starting 2017 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WaStateTacomaGirl, Dec 16, 2021.
  1. Dec 16, 2021 at 8:53 AM
    WaStateTacomaGirl
    WaStateTacomaGirl [OP] New Member
    2017 Tacoma
    Hey Everyone,
    I bought a 2017 Tacoma this spring and it's an awesome ride. This morning it was 26 degrees and it remote started fine, then I hop in to drive to work and the wheel is locked and it won't start. Said check charging system & engine light was on. It tool disconnecting the battery for 2 minutes and reefing on the wheel to get it started. Now I'm paranoid....
    I had an issue with a packrat in the engine compartment this fall but have since repaired the damage and seen zero sign on them. I'll take a closer look when it warms up....brrr.
  2. Dec 16, 2021 at 10:08 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome aboard!
    Sometimes the steering wheel lock is a pain. You need to wiggle jiggle the wheel lightly while turning the...Wait! Do you have a key or a fob?
  3. Dec 16, 2021 at 2:25 PM
    WaStateTacomaGirl
    2017 Tacoma
    It's got a push button ignition and a fob to remote start it.
  4. Dec 16, 2021 at 2:27 PM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    fob battery
