Trouble starting all of a sudden
Discussion in '1st Gen. Tacomas (1995-2004)' started by josh.., Sep 23, 2009.
  1. Sep 23, 2009 at 8:48 AM
    josh..
    josh.. [OP] Well-Known Member
    Sarasota, Florida
    '02 SR5 V6 4x4 Double Cab
    K&N drop-in air filter, body lift.
    Go out this morning, go to start it, same as every morning. Turn the key nothing happens whatsoever. Fuel pump comes on, but no sound from the starter. The lights in the dash are all on, radio is on, ac is on, seems normal as usual, it just isn't starting. I messed with the battery terminals making sure they were tight and the negative was a bit loose, but I tightened it and still no go. I have never had a problem with the truck before today, and this is something that is completely confusing me.
  2. Sep 23, 2009 at 9:55 AM
    Scott41984
    Scott41984 Well-Known Member
    Birmingham, AL
    00 TRD Prerunner V6
    If you hear one click it is the starter
  3. Sep 23, 2009 at 10:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Could be the battery.
  4. Sep 23, 2009 at 11:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Pull the terminals off the battery and clean them up good. Put them back on and try again.
    I'd start looking at the battery first and foremost. I had a similar situation with my 96.....and it was the battery.
    After that....you could tap on the side of the starter and see if that helps.
