Trouble starting at high elevation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoReilly, Mar 25, 2021.
  1. Mar 25, 2021 at 10:03 AM
    tacoReilly
    tacoReilly [OP] New Member
    2011 Tacoma SR5
    I have a 2011 sr5 with the v6, been having a hard time starting at high elevation recently. I live in SLC at about 4000 ft elevation, starts just fine at home regardless of outside temps but if I head up above 8000ft to one of the local ski resorts the truck will crank but doesn’t want to turn over at first, turns over after a bit of cranking or on the second try. At first I thought it was cold related but that doesn’t seem to change anything. Any ideas what this could be? All suggestions greatly appreciated
  2. Mar 25, 2021 at 12:07 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Could be you need to clean the MAF sensor. May not be reading enough air coming in to start. That's a wildly uneducated guess but I would start there. Tell us about your maintenance.last time you did a Plug change , air filter change etc.
  3. Mar 25, 2021 at 12:10 PM
    tacoReilly
    2011 Tacoma SR5
    Thanks for the idea! Spark plugs were changed about a few weeks ago, didn’t seem to change anything at high elevation. Battery is less than a month old, not sure about the air filter I can’t remember when that was done last.
  4. Mar 25, 2021 at 12:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    check to see what your ECM thinks the atmospheric pressure is and compare to a known value, could be a bad or drifting Barometric Pressure Sensor. The ECM uses this information to make adjustments to fuel trim and engine timing.
    For every 100 m (328 ft.) increase in altitude, pressure drops by 1 kPa (0.15 psi).
    Tacoma559, deanosaurus and Dm93 like this.
  5. Mar 26, 2021 at 12:30 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    What I've found is that my truck likes the throttle to be opened somewhat at high elevations when it's started. If I do this it always starts the first time; if not, it struggles. Not floored, but like a 1500 RPM type position. This makes sense since the atmospheric pressure is significantly lower and therefore less air is entering the combustion chamber.
    tacoReilly[OP] likes this.
  6. Mar 26, 2021 at 12:35 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I think that's in your mind. Holding your foot on the throttle doesn't do anything before the truck is running. It will establish the idle position through the ETCS, which is determined by the ECM. The sensor that monitors barometric pressure should compensate for that signal to the throttle actuator.
    Jimmyh likes this.
  7. Mar 26, 2021 at 12:45 PM
    Steve_P
    TN
    Dunno, it works for me. My truck always starts no issue at up to 5k ft elevation on the first try, no foot on the accelerator, no issue. If i'm 8-11K feet it will often start for a second, and then die. Try again, and it cranks fine but nothing. If I open the throttle (yes, I know it's by "wire") it will start every time.
    6 gearT444E likes this.
  8. Mar 26, 2021 at 12:48 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    that's strange, but hey it if works keep doing it! I could see that being required in a carbureted vehicle but seems odd for fuel injection with injectors and spark controlled by ECM.
  9. Mar 26, 2021 at 12:56 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The described symptoms seem like related to the starter circuit and not the fuel injection system.
    Suggest to check the battery connections and the entire starting system.
    Or am I understanding your description incorrectly?
  10. Mar 26, 2021 at 7:14 PM
    Taco'09
    Taco'09 Well-Known Member
    Ha great minds think alike. I wonder if we have seen the first barometric pressure issue controlled by that little, but expensive, pressure sensor located near the back of the engine.
