Trouble starting engine... happens every few months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black 09, Jan 30, 2012.
  1. Jan 30, 2012 at 11:43 PM
    Black 09
    Black 09 [OP] Member
    Vancouver BC
    09 TRD DoubleCab LB
    Seems be happening every few months now that I go to start my truck (2009 TRD) and it just wont start. Battery is brand new, starter cranks good, but engine just wont fire up. After a few seconds I turn back the key, give it a few seconds to rest (just seems like the right thing to do ??) try again and it usually fires up on the second attempt.... sometimes the third. It never happens twice in one day... it has happened in every season warm and cold, but never when its still warm from running.
    Any ideas what on earth is going on????
    Thanks.
  2. Jan 31, 2012 at 7:50 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Does this happen when it is really cold? My truck usually starts after 3 cranks always, but one time it got really cold, below zero I think and it took a little more cranking to start. How many miles are on it? What spark plugs do you use, and how many miles are on them?
  3. Jan 31, 2012 at 9:00 AM
    rdrnr
    rdrnr Member
    My truck does the same thing, only after sitting overnight or for several hours.
    It has done this about 2 times over the last 4 months. It seems like it will start then shuts off. When I try again to start, it cranks quite a bit before starting. I have tried staybl and fuel system cleaners as this happens in the cold temps. The both times it happened after filling the tank with Mobil gas? Next time in for an oil change I will see if the dealer can pull any codes.
    2010 Tacoma TRD sport V6 20,000 miles
  4. Jan 31, 2012 at 9:10 AM
    rdrnr
    rdrnr Member
    I just read this, sounds interesting.
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    Here's my put on this. My 2010 has had similar issues. Not as bad, but it has happened. After starting and running my rig in the morning and parking it at work I noticed the hard start issue. Actually thought I was gonna flood it a few times. I posted and got a pretty advice that seemed to help. It seems that when you start your rig if your like me you put the key in an immediately turn it over. Someone suggested that because the Taco's has electric fuel pumps you might want to wait a couple of seconds before turning the truck on. The suggestion was to let the door chime a couple of times before turning it over. This gives the fuel pump a chance to prime.
    All I can say is when I have done this I have had less issues. Give it a shot before going all out. Never know.
  5. Jan 31, 2012 at 11:06 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    ^^^ good info. I usually let it sit "on" not started for a few seconds before starting it. Have never had that problem, even with a vancouver truck. Have had some problems tho with my dads 08' accord starting lately. Maybe better spark plugs?
    Nice vette rdrnr
  6. Jan 31, 2012 at 11:35 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    there's a tsb for this. search for "hard start tsb" or something to that effect.
  7. Feb 1, 2012 at 8:24 AM
    Black 09
    Vancouver BC
    09 TRD DoubleCab LB
  8. Feb 1, 2012 at 8:28 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Turn the key to the "ON" position for a couple seconds before you crank it. That lets the fuel pump prime and build fuel pressure. I used to do this when I drove a turbo car with a bigger fuel pump and modified fuel maps so it became habit. I do it to every vehicle I drive now.
  9. Feb 1, 2012 at 10:36 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I reliably have hard starts when I get gas from a different station than usual. I don't know if the gas is bad or if the engine just doesn't like it as much, but the 3 times it's done it have all been a couple days after filling up at the BP station down the street instead of the Exxon I usually go to.
