trouble starting in heat
Discussion in '4 Cylinder' started by mylittleblu1996, May 13, 2012.
  1. May 13, 2012 at 1:41 AM
    mylittleblu1996
    mylittleblu1996 [OP] New Member
    san diego ca
    96' toyota tacoma
    anyone in the 96' range have trouble starting their vehicles when the weather is warm? it just tries and tries but doesnt turn over. Summer is coming and I dont want to have to deal with this again. everything seems to be working fine. sometimes i have to wait 10 minutes for it to finally catch.:confused:
  2. May 13, 2012 at 3:28 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    mylittleblu1996,
    Are you saying the engine does not turn over? Or are you saying it does not start when you turn the engine over with the starter?
  3. May 13, 2012 at 7:07 AM
    DESTROYERRACER
    DESTROYERRACER Well-Known Member
    Sean
    Buffalo NY
    10 RC 4x4 5 speed
    2010 Reg Cab 4x4, de-flapped, OME 884s/90000s, Wheelers leaf packs/Bilsteins, Audi A8 headlights, 255/85-16 Cooper ST Maxx's, 8 inch Type R sub, JL door speakers, 1000 watt amp, carbon filter nixxed and K and N air filter because its not dusty here and I do ALL my own work
    is it possible that its warm enough outside and your exhaust or some heat causing source on the vehicle could combine to form a vapor lock in your fuel tank keeping the motor starved until it cools down a bit and then you can start it?long shot but ive seen it happen before
  4. May 14, 2012 at 9:44 AM
    mylittleblu1996
    san diego ca
    96' toyota tacoma
    Im saying it turns over but doesn't start. The issue with the vapor lock could make sense becuae after a while of trying to start it I smell fuel. Any ideas on how to solve this. Your comments are very much appreciated. :)
  5. May 14, 2012 at 9:55 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Neither of my Tacomas I have owned are big fans of starting when it is hot out. No idea what it is, but they definitely seem to struggle more when the weather is warm or if they were recently turned off.
  6. May 14, 2012 at 7:00 PM
    wolftree
    Rick
    Ohio
    mylittleblue1996,
    What maintenance has been done to your truck in the last 50,000 miles?
