Trouble starting in hot weather
Discussion in '1st Gen. Tacomas (1995-2004)' started by NickJ*97756, May 16, 2010.
  1. May 16, 2010 at 10:12 AM
    NickJ*97756
    NickJ*97756 [OP] Well-Known Member
    Nick
    La Grande OR
    95 Red Ext. Cab
    Black Ultra Type 175 Rogue wheels, 33x12.50's, exhaust, sony deck,JL tweeters, hella 500ff's, painted rear bumper, brush guard, tail lights, kc's, custom tube bumper,5100's w/trd springs, toytec aal, custom tire carrier
    Last summer my truck always had trouble starting after i drove somewhere when its hot out. it would turn over but not start. I would have to try a bunch of times. It has started to get hot out now and it just did it to me the other day. Any ideas? -Thanks
  2. May 16, 2010 at 10:16 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    All I can think of is a new starter?
  3. May 16, 2010 at 10:28 AM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    my camry does that and my truck has started to also, not when it hot out , just normal weather, but after i go for a drive and the engine is warmed up then i shut it off then start it 5 min later. it has trouble starting still does though.
    i thought spark plugs or starter as said above
  4. May 16, 2010 at 10:37 AM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    spark plugs are new
  5. May 16, 2010 at 11:42 AM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    any other ideas? anybody?
  6. May 16, 2010 at 1:44 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    If it turns over then its not the starter, it is an ignition or fuel delivery problem. I would say its an ignition problem if it is effected by heat. Does your check engine light come on?
  7. May 16, 2010 at 6:32 PM
    adiablo420
    adiablo420 Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    having the same problem..my 96 doesnt want to start after its warmed up.. i had a code for a tps sensor..replaced it and still the same.. i would like to know what it is..
  8. May 16, 2010 at 6:34 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    i have the same problem with my 96.been trying to avoid going to the dealer... had a code for tps sensor.replaced it and same problem.didnt fix that.. i would like some help myself on this...anybody
  9. May 16, 2010 at 6:36 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    i have the same problem with my 96 2.7 4cyl 4x4.. i had a code for a tps sensor. replaced it and didnt fix that problem..i could use some help myself..
  10. May 16, 2010 at 8:01 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    nope there is no check engine light on
  11. May 16, 2010 at 9:25 PM
    Skolfoppa
    Skolfoppa Member
    MN
    Black 3.4 TRD
    BFG TAKOs, Deck Plate, k&n, Bullie w/ PIAA 520s, Alpined w/ 8" sub, All Mobil 1 synthetic.
    Thoroughly clean your throttle body. Replace your air filter. Seafoam your gas. Then reset your ECU and get out on the highway for a few miles. Skol.
    *You did do plug wires at plug change?
  12. May 17, 2010 at 1:31 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    thoroughly cleaning the throttle body .. does that mean remove and thoroughly clean.. i removed the air intake pipe and cleaned inside there and still same problem... but didn't remove throttle body completely...
  13. May 17, 2010 at 1:39 PM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers
    Had an '89 that did tahe same thing. Did the throttle body service, plugs, rotor & cap, plug wires turned out to be distributer. Brought it to Toyota a whole bunch of times they could never figure it out. Dont know if it is the same problem for you? If its orginal you might want to change it?
  14. May 17, 2010 at 4:03 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    Man.. i just replaced the rotor, distributor cap, plugs , tps sensor... still have the same problem.... question.. did you replace it with a toyota distributor or an aftermarket. ?
  15. May 17, 2010 at 4:15 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    I had a shop run a high pressure cleaner through my throttle body. I dont think that is it.
  16. May 17, 2010 at 6:44 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    did that fix the problem?
  17. May 18, 2010 at 5:59 AM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    no it still did it after i got that done last summer.
  18. May 18, 2010 at 6:54 AM
    mak90
    Central Coast, Ca.
    I replaced it with an aftermarket. Still going 255,000 miles on it.
  19. Jun 28, 2010 at 8:16 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    So I have this same problem on my girlfriends 96 tacoma. When its hot out and after i have driven it, it won't start for about a half hour so one day I checked it for spark while it wouldn't fire. I had no spark for a half hour then it started. I have replace starter, cap and rotor, plug wires. What would cause no spark for a half an hour?
  20. Jun 28, 2010 at 8:38 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    Intermittent hot start problems can indicate a failing Hall-effect sensor, either Crank Position Sensor or Camshaft Position Sensor. This is very common at 100-150k miles on European cars with Bosch sensors, but less so on Japanese makes. Oftentimes they don't throw a code until they die for good (which means "no start" at all, ever.)
    If it's really bugging you, you might swap-in a known good Crank Position Sensor. I would guess the part is $75.
    Dave
