Trouble starting in the cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma02TRD, Dec 11, 2008.
  1. Dec 11, 2008 at 5:57 PM
    Tacoma02TRD
    Tacoma02TRD [OP] Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    I've been experiencing trouble starting my Tacoma when it gets really cold out. I'd say once it gets below freezing. What will happen is that I go to turn it on and it'll make and awful high pitched grinding sound. So I'll quit and then try it again and it starts up just fine. I'm wondering what I could do to make it so that I can just turn the key and not have to worry about it. IDK if new plugs are going to help elevate this problem or if there's something more I need to do. So let me know what you guys think is up.
  2. Dec 11, 2008 at 6:02 PM
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    i have the same problem man... i think chris said that it is a common problem in the first gen tacos
  3. Dec 11, 2008 at 6:07 PM
    Tacoma02TRD
    02 Tacoma TRD
    ^^^ The battery is only a little over a year old. I'll take a look at the terminals tomorrow and see if I can't clean them up a bit. Sure hope its not the starter but who knows thanks for your input!
  4. Dec 11, 2008 at 6:07 PM
    Tacoma02TRD
    02 Tacoma TRD
    I'm glad I'm not alone on this one
  5. Dec 11, 2008 at 6:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The grinding sound is indicative of a starter/battery problem
  6. Dec 11, 2008 at 6:13 PM
    Tacoma02TRD
    02 Tacoma TRD
    Alright good to know I'll take a look at it tomorrow. Thanks for the help.
  7. Dec 11, 2008 at 6:17 PM
    mclapperton
    mclapperton Well-Known Member
    Sacramento, CA
    2019 TRD Sport
    The cold might be causing the stater pinion not to engage the starter ring gear completely on the first shot. Could be that your starter's getting tired. Only other thing I could think of by what you're describing could be worn teeth either on the ring or pinion gears.
  8. Dec 11, 2008 at 6:47 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    My truck has trouble starting when it's cold out too. There is this TSB about starting problems, but I have a feeling the problem is because of the starter instead of a ground.
  9. Dec 11, 2008 at 7:26 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Try getting a pipe warmer and putting it on your starter. See if keeping it warm helps out. You can get them at any hardware for $15.
  10. Dec 12, 2008 at 9:00 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Alright, I was out shopping earlier. Whenever I first started the truck, it sounded real weak and took about 5 seconds to start. After I got done shopping, I went out and started my truck pretty easily. Think it has something to to do with the engine temp?
  11. Dec 13, 2008 at 5:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sounds like the battery. Upon first start, the battery is weak, but after being driven, the alternator is chargeing it back up, so it starts more easilly. Mine does this just before the battery goes bad.
  12. Dec 13, 2008 at 8:56 AM
    pittim
    Pennsyltucky
    Boujee Prius
    Is the little window thing that is supposed to show battery health accurate at all?
  13. Dec 13, 2008 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No.
  14. Dec 15, 2008 at 7:05 PM
    pittim
    Pennsyltucky
    Boujee Prius
    I don't think it has to do with the battery. I went out to do some shopping today, and it started up fairly easily. Temps today were mid 40's, whereas whenever it was having trouble it was probably mid 20's. So I'm assuming that it has something to do with ambient temperature...
  15. Dec 15, 2008 at 7:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Colder temps reduce battery output.
  16. Dec 15, 2008 at 7:31 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I bet it's the starter. My old blazer did that a couple times, both times turned out to be the starter going out... Make sure to carry a wrench around with you (to smack the starter when u get stranded)
    just my .02
  17. Dec 15, 2008 at 7:33 PM
    sonjay
    sonjay Well-Known Member
    Before you shut your truck off try turning all accessories off, and let it idle for a minute or 2. See if that helps any.
  18. Dec 15, 2008 at 10:17 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I would say battery. I notices a "slugish" start on thanksgiving. That evening I used my truck to light my friends front yard for 5 minuted while he got firewood. My truck wouldnt start after that.
