Trouble starting my 06 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by my06tacoma, Apr 26, 2016.
  1. Apr 26, 2016 at 10:10 AM
    my06tacoma
    my06tacoma [OP] Member
    Hi guys, I'm new here, and i'm reaching out to the wise guys here for some help.
    I own a 06 tacoma, and and lately i have some issues with it. I don't know were to start looking for remedies.
    The car was running perfectly fine, with no issues whatsoever.
    I did some work fixing my after market in dash GPS radio yesterday.
    In order to have proper access to it I removed the plastic frame around it with the hazard switch and also the fan controls assembly. Disconnected the connectors and worked for a while to assemble my radio.
    After I finished I put everything together, but my car will not keep running anymore.
    Will start for a second and die.
    One hour before that was running perfectly fine.
    I checked the alarm deterrent light on the assembly I removed while working on the radio. It is blinking but when I will insert the key in the switch the light will turn off.
    I'm assuming is something related to the alarm system what shuts off my engine.
    Any thoughts? I checked for more info on this but I could not find a lot.
    Is hard to believe is a coincidence and the fuel pump or something else broke.
    Are there any fuses I should check, or relays?
    At this time the truck is stranded on the street. I will have to tow it to a dealer for diagnostic.
    Any help will be greatly appreciated.
    2006 Tacoma 4X4 V6 SR5 all stock
  2. Apr 26, 2016 at 10:14 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Start symple. Disconnect neg battery cable for a couple minutes.
    It does sound like an imobilizer problem. Can you try a different key?
  3. Apr 26, 2016 at 2:07 PM
    my06tacoma
    Thank you for your suggestion . I'm going to try that.
    I also tried to use the other key I have. No change, exactly the same as using the original key.
    I will disconnect the battery for a few minutes and go from there.
  4. Apr 26, 2016 at 2:58 PM
    my06tacoma
    Disconnected the battery neg for 15 min. Connected back, the same issue. The engine will start but die right away. Pressing the gas is not helping.
    If I'll try to start it again right way will crank but not fire. If I wait a couple min will fire again for one sec.
    Lost here. Any thoughts? How to reset or bypass the imobilizer?
    Need to troubleshoot and check one thing at the time.
    If by mistake I made a short during the radio install what fuse should I check?
    I checked the fuses from under the steering wheel. Everything looks good.
    I don't know how to actually check the relays.
  5. Apr 26, 2016 at 3:03 PM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    as much as you may not want to you can disconnect the new radio setup, cap the wire to ensure no grounding, and see if that remedies the issue. try a few starts to be sure.
    its somewhere in there
  6. Apr 26, 2016 at 4:17 PM
    my06tacoma
    Yep, I did think about that too. That was my first check. I took everything apart again and even disconnected the harnesses completely. Still the engine will get shutoff.
    Running out of options. Anybody else experienced something similar?
    Is there a way to reset this whole system?
  7. Apr 26, 2016 at 6:49 PM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Hmm, that's weird. Did you check the fuses in the engine bay? What about any codes?
  8. Apr 27, 2016 at 8:34 AM
    my06tacoma
    More checking last night, got a OBD tester and checked for codes. No codes are recorded.
    I'm assuming that something happened to the communication in between the alarm system and the rest. The key chip is being recognized I see the light stop blinking when the key is inserted in the contact, but somehow something is happening after that.
    Messy...
    Any ideas?
  9. Apr 27, 2016 at 7:42 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have no answers for you my friend, but this is why I hate the engine immobilizer systems. I am very glad my 2.7L 4 banger doesn't have it.
  10. Apr 28, 2016 at 12:47 AM
    MarX
    Mark
    NE Kansas
  11. Apr 28, 2016 at 1:22 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Most likely the fuel pump. It seems like most of the time that is the problem for 2nd gen with no start condition.
