trouble starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tntacoma, Jan 16, 2009.
  1. Jan 16, 2009 at 12:54 PM
    tntacoma
    tntacoma [OP] Well-Known Member
    tn
    I have a 07' taco and every now and then, lets say one in 25 starts, it seems like the engine is not firing or aleast it wont start. turn the key off and try again it starts right up? anyone else have this problem?
  2. Jan 16, 2009 at 1:25 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    yes, i have the same problem occasionally. it's probably happened to me 5 times total (had the truck for 2 months now). i can't seem to come up with any pattern and my dealer checked it over - nothing. there is a tsb on extended crank up to 07 - you want to search for that and have the dealer take a look (i think its just an ECU reflash). i haven't been able to determine if that same thing will work for an 08 yet
  3. Jan 16, 2009 at 1:26 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I think that they can re-flash your ECU to fix this, but I thought it was only for 2006.
    How many miles on your truck?
  4. Jan 16, 2009 at 1:57 PM
    DEPJDMALONE
    DEPJDMALONE Member
    ohio
    08 Silver TRD Double Cab
    Mine is an '08 with 3500 miles. I have had it happen about three times so far.
  5. Jan 16, 2009 at 2:03 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    I have an 08 and tried to use that TSB but they didnt let me. And they didnt even fix anything. sucks
  6. Jan 16, 2009 at 2:19 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have an 06' and its happened to me about 2-3 times but it was really cold out those 2-3 times!!!:eek:
  7. Jan 16, 2009 at 2:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have been looking into this for some time. First, I think the problem lies in that the plugs are not gapped correctly from the factory. From what I have found, the plugs are gapped to narrow, resulting in an ineffiective spark. One solution is to pull the plugs and check to make sure they are gapped correctly (.040). Another solution I have been working on is when you go to turn the key to start it, hold the key about 1 to 2 seconds AFTER the truck starts to fire. the starter has a built in shut off for the starter, and it will disenguage it after the motor is running.
  8. Jan 16, 2009 at 2:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    usually.......when i crank mine(did it the same way as i did the 06 i had).......turn key and you can =hear fuel pump prime......then crank. usually does the trick.
  9. Jan 16, 2009 at 2:52 PM
    wawireguy
    wawireguy Well-Known Member
    Could be fuel filter. I found out the hard way that there is water in gas. LOL. My older Buick was running good. Pulled into gas up and pulled out and no runnin till I changed out the filter. So.. who knows, could be your having some probs getting fuel up to pump? Fuel, air or spark..
  10. Jan 16, 2009 at 3:07 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    waiting for 1-2 seconds has seemed to help but sometimes i forget. I will pull my plugs and gap check each one and adjust if necessary - good to know.
  11. Jan 16, 2009 at 3:08 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    is there a fuel filter? i thought only a screen inside the tank on new vehicles? i wish there was one if not. i've also been running heet in the gas every so often - darn cold here
  12. Jan 16, 2009 at 3:09 PM
    wawireguy
    I throw heat in now once in a while. Better safe than sorry. There's a real filter in there for sure.
  13. Jan 16, 2009 at 5:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its in the tank.
  14. Jan 16, 2009 at 7:27 PM
    NewJay
    NewJay Well-Known Member
    Paris, Texas
    05 Prerunner TRD SR5
    3" Lift EZ-lift, True Flow XDI intake, UWF step tubes, 18" Moto Metal 957 Black Magics (black Chrome), Nitto 275/65/18 AT., Custom painted engine cover.
    Same problem I have an 05 model. this just started about 2 weeks ago it will spin over and over and then when i turn the key off then try again bam it cranks right up, I have a good friend who is a master toyota mechanic chief I will take to him tomorrow to flash it and will post results.
  15. Jan 16, 2009 at 7:50 PM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    Yep, this is exactly what I used to do with my Wrangler.
  16. Jan 16, 2009 at 8:42 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
  17. Jan 17, 2009 at 3:12 AM
    tntacoma
    tn
    Thanks guys, good to know im not alone. My taco is still under warranty so off to the stealership next week.
  18. Jan 17, 2009 at 8:17 AM
    surfsupl
    Gregg
    WestCoast
  19. Jan 17, 2009 at 9:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  20. Jan 19, 2009 at 12:20 PM
    off road yota
    off road yota Razorback Fan
    Fayetteville, AR
    Offroad package
    Seat Covers, Exhaust tip, Roof Rack, All weather floor mats, Skid plate
    I have an 07 and when I first got it there were a couple of times it wouldn't start at all, wait 5 minutes and bam fire right up. I took it to the dealership and got my ecu replaced and haven't had any problems since. The guy at the dealership said it had something to do with the anti-theft device in the ecu not recognizing the key. I am not sure but I know that I did get a new ecu and it hasn't happened since. Hope you get that figured out.:D
