trouble starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tntacoma, Jan 16, 2009.
  1. May 21, 2009 at 7:19 PM
    popealope
    popealope Member
    St. Albert, Alberta, Canada
    2005 Tacoma 4DR SR5 TRD Sport Speedway Blue
    I have a 2005 Taco 40K miles on it and am having the same problem. I am not sure if this is covered under warranty, would it be under the 5 year powertrain warranty? If not how much does it cost to get this done not under warranty?
  2. May 21, 2009 at 7:59 PM
    snowtaco
    snowtaco Well-Known Member
    Cali and Pa
    2006 single cab
    Replaced head unit, tint, blacked out tail lights, 10in sub, billet grill, 3 in front lift, led halo projector lights, camper shell.
    im at 60k with no problems
  3. May 21, 2009 at 8:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it should be covered,as there is a tsb for reflashing the computer. go into the dealer and tell them you are having problems with extended cranking, and you know there is a tsb for it.
  4. May 21, 2009 at 8:45 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    My '08 has done it from the start. Not that big of a deal, more of a minor annoyance than anything...
  5. May 21, 2009 at 9:00 PM
    popealope
    popealope Member
    Cool, thanks guys, yeah it is more of a minor annoyance and I am not too stressed about it. It just looks kinda lame when someone is in the cab with you and it won't start. When this happens I say "Yeah it doesn't start but it looks pretty cool"
  6. May 27, 2009 at 6:44 AM
    popealope
    popealope Member
    The Toyota technical service bulletin for this problem is EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition and here is the way to fix it: http://www.empirepao.com/tsb/T-EG011-07.pdf
    I am going to the deal today to get this done so I will report back how it went.
  7. Jun 5, 2009 at 1:47 PM
    popealope
    popealope Member
    So I went to the dealer and got the ECU (ECM as they say in Canada) recalibrated but it doesn't seem to have worked, when I tried starting it today I have the same issue. By the way the Canadian TSB# for this problem is 2734 and it was covered by the powertrain warranty. I wonder if the ECU is faulty and it needs to be replaced or if it is another problem. I have an appointment with another shop to see if they can track down the issue.
  8. Jun 6, 2009 at 8:04 AM
    hoosiertaco
    hoosiertaco Well-Known Member
    ^^thanks for the update. Let us know what they find.
  9. Jun 6, 2009 at 1:14 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    my truck did the same thing the other day. it doesnt happen often and there is no pattern of when it happens, just very random
  10. Jun 26, 2009 at 8:01 PM
    popealope
    popealope Member
    OK, I feel like an idiot, someone mentioned to me that I should try putting my clutch right to the floor when starting (I have a 6 speed manual) like when you shift into 4L. If I do this when starting I never have this problem anymore! It has been almost a month and I never get this issue anymore as long as I put er' to the floor when I start it. I thought I was putting my clutch to the floor but now I make an effort, force it down as far as it will go, turn the key, and it fires up no problem. Go figure!
  11. Jun 26, 2009 at 8:14 PM
    silversavage
    silversavage Active Member
    San Francisco, CA
    09 Silver Crew Cab TRD
    Same issue here 650 miles only happened twice and I didn't turn the key long enough
  12. Mar 24, 2014 at 9:11 PM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Did this ever get addresed? my 06 prerunner has just started to do this. Anyone know if the ECU Reflash actually works? Or is this just a waste of time?
    77k Miles.....
  13. Mar 25, 2014 at 5:15 PM
    browntaco
    browntaco Member
    Wade
    Ohio
    09 Trd SR5 V6
    aluminum TRD rims.
    i have this problem with my 09, it has only happened about 4 times in the past 2 years (the amount of time iv owned it) it happens only when its rainy and cold out..some one i know has the same problem with a dodge 1500:bored: same scenario only when its rainy and cold
  14. Apr 13, 2014 at 10:06 PM
    njcoma
    California
    hmmm....took mine to the dealer....its already had the ECU reprogram done....so that isnt the issue...
    again...hmm.... but...hasnt done it since i took it to the dealer...
    one of those things.........
