Trouble Tuning Hood Mounted Wilson Flex CB Antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by plurpimpin, Sep 7, 2011.
  1. Sep 7, 2011 at 9:46 AM
    plurpimpin
    plurpimpin [OP] Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I installed my cobra 75 last week and am using a 3' wilson flex antenna with it. The antenna is mounted on a relentless fab hood hinge mount. I keep getting high SWR readings. 3:1 on channel 1 and 2:1 on channel 40.
    I've checked my grounding and everything looks fine. I've also tried a variety of adjustment tip lengths and they I still can't get the SWR low enough. Anybody have any ideas?
  2. Sep 7, 2011 at 3:32 PM
    plurpimpin
    PDX
    I've already done that. I've checked everything with a multi meter. The cables are good, the antenna is good, and the mount is grounded.
  3. Sep 7, 2011 at 3:42 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    just try putting it on the roof of the cab and see if thats any better. it just might be too short for your aplication and isnt above the cab enough
  4. Sep 7, 2011 at 3:43 PM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    try grounding with a very large cable...like a set of jumper cables, see if you get a better reading. ive heard of people having problems because their ground wasn't strong enough. i also recently talked to someone at firestik, and they told me a little 12ga wire/grounding to the thin body metal doesn't cut it (in most cases).
  5. Sep 7, 2011 at 3:54 PM
    plurpimpin
    PDX
    Ground the antenna itself or the mount? In the antenna's directions it said to only use the ground on the antenna with certain types of radios. When I grounded my antenna itself it raised my SWR. My mount is grounded through the hood hinge bolts. Should I try putting an actual grounding cable on the mounting bracket?
  6. Sep 7, 2011 at 4:07 PM
    plurpimpin
    PDX
    Just hooked a jumper cable from my antenna base to the frame, made no difference in SWR. Also checked with a multi meter, the base has a good ground to the body
  7. Sep 7, 2011 at 5:06 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    hm, im not sure then. if youre using a 3' antenna, the problem (as UMBCrew said) could be you arent getting it high enough above the cab...i know a lot of companies recommend the antenna be at least 2/3 about the cab. good luck, let us know what you find out.
  8. Sep 7, 2011 at 7:09 PM
    plurpimpin
    PDX
    This is what I've been thinking. I just figured I'd try every option before I go out and buy a 4' antenna but that's looking like that'll be the case.
  9. Sep 7, 2011 at 7:15 PM
    White Bear
    White Bear Well-Known Member
    Louisiana
    Probably have the only 2nd Gen with an 8274 in the world.
    Hey, use copper braid ground straps and ground your hood to the front quarters (I used the hood hinge bolts), the rear quarters to the frame, the front quaters to the frame. Make sure to scrape/sand down to bare metal to insure good connectino. The body panels on these trucks are not grounded well, I went through the same thing and got my swr to 1.2 or so. I mounted my antenna in the front passenger corner of the bed, a Wilson 2000.
  10. Sep 7, 2011 at 10:24 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    this is what i was thinking.
    do you have pics of your setup, specifically the ground wire location? ive been wanting to run a thick copper braid ground from my behind the cab mounting location, but dont know where to run the wire/how i want to ground to the truck.
  11. Sep 8, 2011 at 4:05 AM
    plurpimpin
    PDX
    wouldn't running a jumper cable from the mount to the frame have tested this though? I did that to be sure it was grounded well and it made no difference in SWR.
  12. Sep 8, 2011 at 4:22 AM
    JKD
    JKD Well-Known Member
    There is a difference between grounding for DC and grounding for RF (radio frequency AC current). Usually you go for short runs of wide copper braid or foil to make an effective RF ground. To make a good RF ground sometimes I'll strip old coax and just take off the braid and put ring terminals on the ends.
    You also want to bond the body panels together and bond them to the frame and negative battery terminal. Hood to body, fenders to body, frame to body, body to battery. Again, RF bonds, not just DC grounds.
    In fact, you usually want to bond the rest of the body panels together too, including the bed, and if you get interference from the ignition system or other engine electronics, you bond the engine and exhaust system to the frame and body too.
  13. Sep 8, 2011 at 4:58 AM
    plurpimpin
    PDX
    anybody know where I can get some copper braid? I'm going to try grounding all the panels tomorrow
  14. Sep 11, 2011 at 8:46 AM
    White Bear
    Louisiana
    JKD hit it - the antenna needs a ground plane to work properly and bonding the body panels together provides such a plane.
    I don't have any pics, i did ground my mounting bracket first, but it didn't give me any better SWR. The bonding process took care of the problem. Keep in mind this took me a few weeks of trial and error to get right.
    I grounded my cab to the frame with a ground strap, too.
    I bought my ground straps at a battery store, they were 8" long.
  15. Dec 15, 2011 at 7:27 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    Did you ever get this figured out?
  16. Dec 16, 2011 at 1:58 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    you should check the cable that you are using going from your meter to the cb. I had a similar problem with tuning and as a desperate last resort I swapped out this cable and discovered that the initial cable was bad.
  17. Dec 16, 2011 at 2:49 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    take it to a local truckstop and seek help there.
