trouble with 4wd
Discussion in 'Technical Chat' started by Krp2nite, Jan 13, 2009.
  1. Jan 13, 2009 at 2:17 PM
    Krp2nite
    Krp2nite [OP] Well-Known Member
    I put new tires on my truck. They are a little larger than the OEM ones and it may be a coincidince but I seem to be having difficulty get the truck into and out of 4wd now. It will only engage under 30mph anything over and it just flashes forever--not the beep / flash of going to fast just a flash and no 4wd. Also taking it out of 4wd makes an increadle clunk and feels like the front end is falling out if done while moving. Everything seems to work when stopped. Anyone know if this could be because of the larger tires, or if there is something wrong. Thanks
  2. Jan 13, 2009 at 6:36 PM
    Krp2nite
    no replies... I guess I will take it into the dealer, I just have a fear that they are going to blame the tires without even looking at it---then as soon as the warranty is out--the real problem will show itself at my expense.
  3. Jan 13, 2009 at 6:38 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Shouldn't you be engaging it under 30mph anyway..
  4. Jan 13, 2009 at 6:39 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    what truck is this anyway? you have two listed
  5. Jan 13, 2009 at 6:41 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I don't have much to offer you but. When I first got my truck it was a little slow and noisey going in and out of 4wd. After using it several times it goes like butta. I have never tried putting it in over a 5mph. Good luck to you. I'm sure someone will chime in w/ better info.
  6. Jan 13, 2009 at 6:42 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    When going from 4x2 to 4x4 and vice versa, i always do it while at a complete stop unless the situation requires me to keep moving (sand) at that point im never over 30mph. It sounds like you've put your transfer case thru some hard times
