Trouble with Cruise Control and ABS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tvbd56, Dec 2, 2011.
  1. Dec 2, 2011 at 11:58 PM
    tvbd56
    tvbd56 [OP] Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    So earlier today i was driving at about 70mph on the freeway and i was using cruise control just fine. I parked, then hopped back in after about an hour and started driving, i got back on the freeway and was driving about 65mph and noticed that my ABS light came on, then i turned on cruise control and went to set it at 65mph and it wouldn't stay at 65mph!!! I tried turning it on and off, and still the cruise control doesn't work.
    Ohh and i have a scanguage and it wasn't giving me any codes, What's up with my truck???
  2. Dec 3, 2011 at 12:16 AM
    tvbd56
    Tyler
    Sacramento, Ca
    that's what i was thinking, but i wasn't 100% sure why the abs would make the CC not work.
  3. Dec 3, 2011 at 9:46 AM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Check your battery. My truck threw a shit load of lights when my battery was dying. And the abs was first to come on.
  4. Dec 3, 2011 at 1:05 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    fixed it for ya;)
    A weak alternator can do the same thing.
  5. Dec 3, 2011 at 2:12 PM
    tvbd56
    Tyler
    Sacramento, Ca
    Really? Huh I didn't know that, I'll check both of them. What makes it weirder is that i drove it this morning and my Abs light was off and my CC worked, now hopefully it'll work for my drive home do i can check it out.
  6. Dec 5, 2011 at 8:48 PM
    wrxRome
    Brandon
    No I mean battery. I had it happen to me. I have a thread bout it but I'm on my phone and can't link it
  7. Dec 5, 2011 at 8:56 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    look for blown fuses. seen that before
  8. Dec 5, 2011 at 9:06 PM
    Sunner
    Sunner Well-Known Member
    My bro's C5 has some ABS problems and I can't use cruise control on it due to it as well
  9. Dec 5, 2011 at 10:23 PM
    tvbd56
    Tyler
    Sacramento, Ca
    so for the past couple days it would keep going on and off, and now it's staying on. The battery is fine and I'll check the alternator and fuse tomorrow, other than that i think it could just be a dirty sensor.
  10. Dec 5, 2011 at 11:24 PM
    wrxRome
    Brandon
    unplug them at your hub and spray the connections down with wd-40 then wipe it dry really good
  11. Dec 6, 2011 at 12:04 AM
    tvbd56
    Tyler
    Sacramento, Ca
    I think I may be doing that tomorrow if nothing else works.
  12. Dec 11, 2011 at 12:49 AM
    tvbd56
    Tyler
    Sacramento, Ca
    i haven't gotten the chance to do much lately since i have finals coming up, but i did figure out that the abs light will only come on when i turn on my headlights. So if i start my truck with the headlights off there will be no abs light, then turn on my headlights and on comes the abs light. And if i turn my headlights back off the abs light will stay on until i turn off my truck... WTF is wrong? this is starting to piss me off
  13. Dec 11, 2011 at 1:01 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    Check your fan belt. If it is loose, your alternator could be slipping with the lights on and causing the low voltage condition to cause the ABS light. I've had a vehicle in the past with a loose fan belt and would discharge the battery only when the lights were on.
  14. Dec 14, 2011 at 11:16 PM
    tvbd56
    Tyler
    Sacramento, Ca
    So, turns out there was a short in my left brake light, which in turn, when my headlights were turned on, tripped the abs light
