Trouble with engine air filter housing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dr.JohnZoidberg, Oct 26, 2021.
  1. Oct 26, 2021 at 7:37 AM
    Dr.JohnZoidberg
    Dr.JohnZoidberg [OP] Member
    2013 Tacoma TRD off-road
    So I know it’s probably the most basic maintenance on our Tacoma’s. However I cannot seem to remove the housing for the engine air filter. I undo the clips in the front, the back seems to be stuck and won’t come off. Any tips on how to remove it? I don’t want to pull to hard and snap the plastic.
  2. Oct 26, 2021 at 7:42 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The back uses hooks.
    Release the clamps. Open a couple inches. Pull towards the front of the truck. It should release with a firm tug.
    I am assuming you have the 1GR-FE (4.0L V-6) engine.
    Geeves77 and grizquad like this.
  3. Oct 26, 2021 at 7:42 AM
    Tacoma Mike
    Southern Maine
    It is easy once you know how.
    When you pull on the front of the housing, reach your finger in and pull the air filter into the part of the housing your removing. Then you can slide it forward and then the back will unhook
  4. Oct 26, 2021 at 7:45 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I take the hose off when I do mine, it makes the air filter much easier to get in and out.
    DGXR likes this.
  5. Oct 26, 2021 at 8:27 AM
    Taco'09
    Taco'09 Well-Known Member
    :thumbsup: Yes. I do too.
    Geeves77 and Dm93[QUOTED] like this.
  6. Oct 26, 2021 at 10:38 AM
    Dr.JohnZoidberg
    Cool. My hose clamp is extremely rusted, I was thinking about removing it but I would hate to destroy the only bolt I have for that clamp
    Dm93[QUOTED] likes this.
  7. Oct 26, 2021 at 10:49 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I can see where that would be a problem, we are lucky enough not to have to deal with rust here.
    I would have to check but I believe the spot on the hose for the clamp is wide enough that you could use a standard worm drive clamp of the correct diameter in place of the factory one.
    (Edit) Just looked, the space is plenty wide to use a standard worm drive clamp there.
  8. Oct 26, 2021 at 2:54 PM
    Dr.JohnZoidberg
    Thank you. The tip that I should stick my finger into the housing and push the actual filter into the housing I’m removing worked.
    Tacoma Mike[QUOTED] likes this.
  9. Oct 26, 2021 at 3:22 PM
    Tacoma Mike
    Southern Maine
    Yea I’ve done one or two lol.
    :thumbsup:
    6 gearT444E likes this.
