Trouble with key fob battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eastxn, Oct 7, 2022.
  1. Oct 7, 2022 at 4:06 PM
    Eastxn
    Eastxn [OP] Active Member
    2020 4X4 White Tacoma TRD off-road
    I am trying to replace the CR2032 battery in my key fob with a new one but the new battery will not seat. The negative side keeps popping out. It's an energizer if that makes a difference. Anyone else have this problem?
  2. Oct 7, 2022 at 4:09 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Can't say I have.
    Have you tried adjusting the clips with a jewelers screwdriver? :anonymous:
  3. Oct 7, 2022 at 4:11 PM
    Eastxn
    I don't have a screwdriver that small. Even if I did I'm not sure I would know what needs adjusting. I did try to reinsert the original just in case I bent something but it snapped right into place like it's supposed to. The new one must be different somehow
  4. Oct 7, 2022 at 4:15 PM
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    Could the original battery be a CR2025?
  5. Oct 7, 2022 at 4:17 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    And a really stupid question - you are sure you're exchanging 2032 for 2032, not 2016 or 2025, right? All have the same diameter, but the thickness can cause issues with certain gadgets.
  6. Oct 7, 2022 at 4:19 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Just googled … CR 2016
  7. Oct 7, 2022 at 4:47 PM
    Eastxn
    The 2032 is for trucks with the smart key system. The 2016 is for those without it. My original is a panasonic CR2032 and the replacement is an energizer CR2032. One thing I noticed is the bottom of the panasonic has a more squared off bottom whereas the energizer is more rounded. So keep that in mind when y'all change batteries.
    Also I went ahead and reassembled everything and with the key fob all together it pushes the battery down into the right place and everything works
  8. Oct 8, 2022 at 1:57 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Do you have it flipped over
  9. Oct 8, 2022 at 4:08 PM
    Eastxn
    No it's correctly oriented but the energizer just doesn't snap into place like the panasonic does. Odd but it works anyway
  10. Oct 10, 2022 at 5:29 PM
    Eastxn
    I went ahead and ordered new panasonic batteries off of Amazon. Energizer seems to be the only batteries anyone sells around here in the key fob size and even though they do work it just really annoys me that they don't seat properly. Got the panasonics today and just like the original ones, they popped right into place so everything is good now.
    Chew likes this.
