Troubleshooting single click on start of 04' v6. No cranking, Replaced starter/batt/relay aleady.
Discussion in '1st Gen. Tacomas (1995-2004)' started by HCFab, Sep 18, 2018.
  1. Sep 20, 2018 at 9:11 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    HCFab[OP] likes this.
  2. Sep 20, 2018 at 9:16 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Deleted, I just checked and you did mention starter relay was replaced.
  3. Sep 20, 2018 at 11:05 PM
    Rabbi
    Rabbi Don't use cannon to kill mosquitoe!
    New Orleans
    01' Taco PreRun 3.4l 2wd
    Mud tires
    Hey brother I had the same issue with my Taco. Check out this thread it might help you out alot. If you need more info pm me.
    Circuit Opening Relay Location???
    HCFab[QUOTED][OP] likes this.
  4. Sep 21, 2018 at 12:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    OP had a original no crank problem.
    Now so many more parts have been introduced to the system any of which may have been bad out of the box !!
    Could be a bad rebuilt starter bad relay now adding to the original problem
    Following this train of not troubling shooting Time for a new Truck
  5. Sep 21, 2018 at 1:52 AM
    Rabbi
    New Orleans
    Mud tires
    I agree Wyoming09, he should properly troubleshoot his no-start condition. Not throw parts at it! Which is why I suggested he read through the thread I suggested. And bc I've had a similar nearly identical no-start condition on my Taco. In addition to that, anyone can make posts like yours while TROLLING through threads. But not everyone can give a little of their time to help a total stranger. And if you're wondering I am an "ASE CERTIFIED TECH" 15+yrs exp.
    But I don't throw that around when I'm just giving a guy a hand, bc we all need help sooner or later and some more than others. Thanks for the response though
  6. Sep 21, 2018 at 2:40 AM
    HCFab
    HCFab [OP] Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    First of all the only "new part" in the system is the starter. That will be back to the original once it is tested at a shop.
    All other things were taken off of my main Tacoma and placed back after a test. They have also been verified to be working a 2nd time with that truck. my bases are covered on those parts.
    I understand the concept of troubleshooting and am not getting ahead of myself in that regard.
    Ideas for things to replace and verify with a 2nd working truck is the way I'm making sure there are no bad parts in the system.
    Woofer2609 likes this.
  7. Sep 21, 2018 at 2:50 AM
    Rabbi
    New Orleans
    Mud tires
    Where'sthe clicking coming from? Underhood, low engine, behind dash?
  8. Sep 21, 2018 at 2:51 AM
    Rabbi
    New Orleans
    Mud tires
    Are there multiple clicks? One brief click?
  9. Sep 21, 2018 at 3:14 AM
    HCFab
    Zach
    Central Idaho
    There is one single click and it sounds like it's coming from the bottom section of the engine, I will verify if it is starter itself after I get off work in about 10 hours,
    Steven G and Rabbi[QUOTED] like this.
  10. Sep 21, 2018 at 7:03 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I assume this is "your" truck and not hers?
    I'm definitely no expert, and I don't know if it would matter but clutch start cancel? neutral safety switch malfunction?
  11. Sep 21, 2018 at 8:14 AM
    HCFab
    Zach
    Central Idaho
    This is my wife's truck with the problem. It's a automatic. Good thinking with the clutch start though, I have had that issue with mine and my plunger switch busted and that caused no start, except there was no click.
  12. Sep 21, 2018 at 8:16 AM
    Glamisman
    Glamisman Well-Known Member
    These are the repairs that drive a tech nuts. You have replaced the mechanical aspects of the system and assuming that the parts put in are in proper working order it appears that there is an electrical issue. You HAVE to do a voltage drop on the wires related to the starting system. This is not a resistance check with an ohm meter this is a test that checks the wires ability to flow current (amps), not volts. Rather that me going over it point by point in a message there are many examples of videos on the interenet showing you the what and why.
    There are 3 main grounds on your 3.4. The first is the ground for the battery on the engine block, drivers side lower front. Give it a wiggle first. The second ground is just off the negative battery terminal to the inner drivers side fender and the third is off the passenger side cylinder head rear to firewall.
    The positive lead goes from the battery down along the front of the oil pan then goes back to the starter.
    Did you take the old starter in to an auto parts store for testing?
    In your info you have both a manual trans and auto trans Tacoma listed. Which is this? The reason I am asking is that the wiring for the neutral saftey is different. I am not there to see if the clunk is the starter relay or the starter. Just because the part(s) are new does not mean they are good.
    Rabbi and HCFab[OP] like this.
  13. Sep 21, 2018 at 9:28 AM
    HCFab
    Zach
    Central Idaho
    Thanks,
    I will be getting a multimeter later today to test all leads and voltage drops.
    I didn't know the location of all the grounds, but I'll be checking each one now.
    The old starter will be tested later today.
    I have 2 Tacomas, mine is manual and the wife's is auto, this issue is on the automatic.
    Thank you for your time!
  14. Sep 21, 2018 at 10:38 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am sorry you missed the humor in my post .
    Time to leave this forum I guess
  15. Sep 21, 2018 at 11:05 AM
    #35
    HCFab
    Zach
    Central Idaho
    :crazy:
  16. Sep 21, 2018 at 11:35 AM
    #36
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Use a good set of jumper cables to by pass the battery cables from battery to starter see if it works then.
  17. Sep 21, 2018 at 5:04 PM
    #37
    HCFab
    Zach
    Central Idaho
    Update: I have tested both new and older starter at O'Reillys and they both work fine.
    The old one sounded a little weak and had a whine but spun fine.
    The new one seemed to be more consistent with pitch and had less play in the pinion.
    I have kept the new starter and reinstalled it.
    No reason to go with a starter that sounded that weak.
    2nd time re-installing the NEW starter and the click is still there.
    Battery reads
    • 12.62v No load
    • 12.50v ACC
    • 12v on START
    Starter reads
    • 12.62v No load
    • 12.50 AC
    • LESS THAN 1V ON START.
    I'M MAKING PROGRESS!
    I'm not sure what exactly this means however.
  18. Sep 21, 2018 at 5:05 PM
    #38
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I would try to get a jumper cable to the starter from the battery and see if it starts
  19. Sep 21, 2018 at 5:08 PM
    #39
    HCFab
    Zach
    Central Idaho
    I'll do it now
  20. Sep 21, 2018 at 5:14 PM
    #40
    HCFab
    Zach
    Central Idaho
    I placed jumper cable on starter terminal and batt pos.
    Turned key.
    It was sluggish like it didn't want to start but it started!
    Leting it run now to recharge batt.
