TRP Off Road E-Locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Twilly, Feb 19, 2020.
  1. Feb 19, 2020 at 10:12 AM
    Twilly
    Twilly [OP] Member
    Troy
    2019 TRD OFF Road
    ICON Lift, ARB, 4:88s
    Anyone having issues with their locker staying engaged?
  2. Feb 19, 2020 at 12:00 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I had mine /not/ engage many times and at this point have basically decided to exclusively use a-trac
    Junkhead likes this.
  3. Feb 19, 2020 at 12:06 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    atrac? automatic traction?
  4. Feb 19, 2020 at 12:09 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Uh, no. A-TRAC is “Active TRACtion” control that provides assistance when wheel slippage is detected.
    AKGSD, Junkhead and Skydvrr like this.
  5. Feb 19, 2020 at 12:12 PM
    mrtonyd
    Tony
    Colorado
    thats the yellow light that pops on when im in 2wd and hit the gas on ice?
  6. Feb 19, 2020 at 12:14 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think that's traction control
  7. Feb 19, 2020 at 12:14 PM
    trackdaybro
    trackdaybro Well-Known Member
    It helps to drive in a “S” left and right when trying to lock or unlock your diff. Helps the splines line up or release tension.
    Ol'gray mare and whatstcp like this.
  8. Feb 19, 2020 at 12:15 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    No, that’s stability control. A-TRAC is a button somewhere inside your truck, if equipped.
  9. Feb 19, 2020 at 12:19 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    How are you guys engaging your locker? If I recall, you have to be in 4-Lo and under 5mph to enhance is and remain in 4-Lo. If you shift out of 4-Lo it’ll disengage and you’ll get the flashing light on the dash.
  10. Feb 19, 2020 at 12:21 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    How are you trying to use it? Gotta give a little more info
    whatstcp likes this.
  11. Feb 19, 2020 at 12:23 PM
    ryan760
    ryan760 Well-Known Member
    atrac = Truck applies brakes to slipping wheels independently
  12. Feb 19, 2020 at 12:24 PM
    Riotfunk
    Taco TRD off road
    Atrac is crawl control. It’s the rotary knob above your noggin. Again 4 low to use
  13. Feb 19, 2020 at 12:40 PM
    Kaptain_02
    Kaptain_02 2019 OR
    Did you have this problem before re-gearing?
    "ICON Lift, ARB, 4:88s"
  14. Feb 19, 2020 at 12:52 PM
    tdavistech
    tdavistech Well-Known Member
    I'm pretty sure you can engage the locker at any time 2wd or 4wd.
  15. Feb 19, 2020 at 1:01 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    No it’s not. Two separate systems
    No, no you can’t. Not unless you trick it by doing a mod to it like the old gray wore mod on the 1st gems.
    Does anyone read their manuals anymore?
    JNG, AKGSD, LivinOnEdge and 4 others like this.
  16. Feb 19, 2020 at 1:21 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    More specifically, crawl control uses A-TRAC, or is another layer above A-TRAC.
    AKGSD and ryan760 like this.
  17. Feb 19, 2020 at 1:26 PM
    tdavistech
    Sadly the manual does NOT say that you HAVE to be in 4WD to engage the locker. It only states that you should try 4Lo first before engaging the locker.
    Why would they write all new code for the 2WD TRDOR's? Go out to your truck, turn it on, and engage the locker. No transfer case required.
    Read page 253 of the instruction manual, it talks about 4wd and the diff but it never absolutley says that 4wd has to be engaged before you can engage the locker.
    https://www.toyota.com/t3Portal/document/om-s/OM04013U/pdf/OM04013U.pdf
  18. Feb 19, 2020 at 1:30 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Maybe the problem is that they sold you TRP OFF ROAD instead of TRD? :notsure:
    44-16 Taco, Riotfunk and tdavistech like this.
  19. Feb 19, 2020 at 1:31 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Manual? Whats that? You mean like manual transmission? I got one yes :laughing:
    Speedfreak likes this.
  20. Feb 19, 2020 at 1:36 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    You should go try it for us and video it
    Skydvrr, ryfox0276 and whatstcp like this.
