TRS BiXenon High Beams turn off entire headlight when switched on
Discussion in 'Lighting' started by JohnNP, Mar 29, 2015.
  1. Mar 29, 2015 at 3:38 PM
    JohnNP
    JohnNP [OP] ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    Hey everyone
    Did a quick search but most of the causes of this seem to be folks didn't use a proper relay or control boxes or theres something not attached, etc. I'm not thinking any of that goes for my issue.
    I recently installed a Morimoto BiXenon System that I got from TRS. Got everything from the Control box to the harnesses/shrouds/projectors all from TRS. I couldn't be happier with the quality of the stuff and had no problems until yesterday. When driving home I wanted to see what the "high beams" looked like now that I was on a nice dark road and when I switched them on they stayed on for 0.5 secs then the headlights shut off. I'd go back to Low beams, right back on they would come. Tried turning off the Fogs and doing it again...same thing, low beams work great, they come on fine, you try switching to high beams even "flashing" them and the lights go off. :eek:
    Opened up the hood today to see if there some something obvious that would explain it, and I can't find a damn thing. All the connections seem fine, the High beam voltage signal is coming from the Blue wire in the TRS harness / Red wire on the stock. I know that it was working when I installed everything but now it shuts off. I had tried the high beams several times on the day of install and they worked. The solenoids are working fine, I can hear them click down and the high beams will work for a fraction then just everything turns off. :confused:
    Thoughts???? Could this be a bad controller.....I don't think it's the ballasts since the low beams work great. I'm planning on calling TRSAndrew tomorrow but before I bothered him, figured I'd give you all a try. :(
    Thanks
  2. Mar 30, 2015 at 11:45 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    It's definitely not the projectors, the cutoff shield inside just drops, having nothing to do with the bulbs. But it seems like it could be a bad controller. Didn't you do something to your h4 connectors? Tapping it for halos, modifying it, etc?
  3. Mar 30, 2015 at 11:51 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    High beam fuse or controller box. Just let us know if it's not the fuse!
  4. Apr 1, 2015 at 5:45 AM
    JoseyWells
    JoseyWells Well-Known Member
    Joe
    Corona, CA
    12 prerunner
    Demello sliders, Icon ext coilovers, icon rear shocks, icons UCAs, 17" Konig Countersteer Type X, 285/70/17 Nitto Trail Grapplers
    Kinda have the same problem except my low beams dont turn on. High beams work when i plug the ballast into the high beam plug. Im thinking it may be the control box. Getting a new one today and gonna see if that fixes the problem
  5. Apr 1, 2015 at 6:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    My bet would be the high beam fuse is blown. Replace it and try it again. If it does it again, you could have the same issue I had, the solenoid froze up in the projector, causing the fuse to blow when I cycled the high beams. Low beams worked fine.
  6. Apr 1, 2015 at 8:38 PM
    JohnNP
    Hobe Sound, FL
    I'll check the fuse as soon as I can, likely this weekend, had a nasty stomach bug that's put me out of commission the past 4 days.
    So did it fix your problem?
    Yeah I'm pretty sure it's the control box for me. I can hear the solenoids click and the high beams do go on for 0.5 secs before cutting out the lights. I'd think the high beams wouldn't come on at all even for a fraction of a second if it were the high beam fuse. I even tested with a volt meter that I have power going to the high beam output on the H4 plug . But I'll be checking it all the same.
  7. Apr 2, 2015 at 7:16 AM
    JoseyWells
    Joe
    Corona, CA
    12 prerunner
    Switched the control box out and it still doesnt work. I'll double check the fuses but if that doesnt work then i have no idea
