TRS group buy: 25% off, Let's see a list! Thanks Matt@TRS!
Discussion in 'Group Buys' started by LEDsolutions, Oct 27, 2011.
Thread Status:
Not open for further replies.
  1. Dec 1, 2011 at 8:21 AM
    #281
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    mine says shipped :yay::woot: to bad i wont be around for a month to install them :pout:
  2. Dec 1, 2011 at 8:25 AM
    #282
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  3. Dec 1, 2011 at 11:57 AM
    #283
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    Whats the install differences between the mini and FXR?
  4. Dec 1, 2011 at 12:00 PM
    #284
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    if my reading is correct the FXR takes some customizing of the reflector
  5. Dec 1, 2011 at 12:01 PM
    #285
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    The Mini slides right into the existing reflector opening. The FX-R will require some fabrication to make the reflector center hole larger and you will need to drill 4 holes to mount the projector.
    The TRS website has PDF instructions for both installs.
  6. Dec 1, 2011 at 12:05 PM
    #286
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    oh sweet, didnt know that. gotta go find it for the mini to help my install. thanks
  7. Dec 1, 2011 at 12:06 PM
    #287
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    TRS uses a Tacoma for the install on the minis. :cool:
  8. Dec 1, 2011 at 12:19 PM
    #288
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    found it, they make it look so simple. hopefully it is as simple as it says
  9. Dec 1, 2011 at 12:32 PM
    #289
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Can you post a link?
  10. Dec 1, 2011 at 1:46 PM
    #290
    Commanderwiggin
    Calgary
    Ok so I'm having trouble deciding between:
    1. Projectors (LHD North America vs. RHD Euro...which is brighter? Euro?)
    2. Sealing glue...is this generally needed or does everyone use something different?
    3. Shrouds...which one for a 2012?
    4. Wire Harness...which one?
    Still waiting on an email back from matt
  11. Dec 1, 2011 at 2:02 PM
    #291
    AsianAnts
    AnT
    1. i dont think its a matter of which one is brighter.. i think its a matter of which one is made for the american streets because we are left side drivers... the step on the projector from left to right is low to hi....It is designed to lower the step so you wont blind oncoming traffic.... Euro is right side driver so the step on the projector from left to right is hi to low.... Iono.. i just totally guess that..... LOL but it sounds legit doesnt it?
    2. Get some sealing glue. Use it in addition to the stock gray butyl thats already there
    3. Which ever your heart desires. Many use gatling gun shrouds (requires some modding). Some use the Apollo. And some use other types.. whatever you think looks best
    4. H4/9003 Wiring harness
  12. Dec 1, 2011 at 2:19 PM
    #292
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    what? neither is brighter each style right hand drive and left hand drive have a step in the cutoff so that you don't blind other drivers.
    if your vehicle is left hand drive then choose left hand drive projectors its that simple...
    shrouds are not model specific to your vehicle if there is room in the headlight housing and the shroud will mate up to the projector then your golden.
    hd wiring harness not the can bus imo. you could use either but, the hd relay harness offers way more protection than is even needed as added insurance.
    butyl rubber/window weld is what is applied in the channel of the headlight. as a matter of fact fuck it dude i would send these to a professional and heres why. if you are using your factory housings your running a very big risk of just plain old ruining them due to your lack of experience. btw aftermarket housing have been known to have inherent flaws that can lead to a whole bunch of issues so if your dropping all this cash do it right use the factory housing and have a professional perform the retrofit.
    factory housing are a solid 450 dollars brand new and thats on the cheap side after market housings can be had for around 90 a pair if you search and the only brands you should be using are tyc and depot brand as they are of way better quality than the rest.
    also just wanted to let you know that "brightness" is determined by only a couple factors non of which you listed. one is projector choice mini H1 fx-r are going to be the best imo. there are other nicer bi-xenon projectors but, their size can seriously complicate the process. the fx-r is hard to beat man it really takes a ls 460 imo to truely best the fx-r basically i would stick to the mini H1 and the fx-r and leave it at that.
    wattage if your running your system with a 35 watt ballast this is the standard wattage and your able to run that on every projector. 55 watt is on average 20 to 30% brighter but you can expect shorter bulb life and for the bulb to color shift more. not to mention that you can not run a 55 watt ballast with every projector ala the mini H1 because it's an open design not a closed design the heat would destroy things.
    bulb choice if you go 35 watt pick a quality bulb ie, morimoto, phillips or osram period.
    and if you end up with 55 watt trs sells their morimoto branded bulbs in 55 watt as well the glass tube is thicker as is the electrode and the base is beefed to handle the extra juice as well. thats what i run and they are awesome.
    kelvin rating, this is where people fuck up constantly! they spend all this money on a nice set-up and ruin it by putting 10k bulbs in there. a higher kelvin rating does not equal a brighter bulb actually in fact it means your losing light and a good deal of it as well. stick to 4300k or 5k thats it. the 5k is pure white light while the 4300 has a tinge of yellow mostly only visible in the cutoff.
    also aiming another way most people ruin a good set-up. take your sweet time aiming them correctly!!! first off you won't get flashed second off they will work better catching street signs and cones and lighting them up like its christmas while still being safe. if and when you get your set-up completed kneel in front of your truck with the lights on and bob up and down you will notice that for a moment while either descending or ascending you will pass through the color flicker. the portion of the cutoff that has the color in it usually blue's and purple's depending on kelvin choice. you want other drivers to stay on or above your color flicker!. that way no one gets blinded and to others your projectors themselves will look blue and purple coming down the road. so you get an asthetic and functional gain from aiming your lights correctly.
    good luck it's more work than your thinking it is and it can get very expensive very quickly.
    hans
  13. Dec 1, 2011 at 2:26 PM
    #293
    AsianAnts
    AnT
    :bowdown:
    btw hans ur buddy still hasnt contacted/reply
  14. Dec 1, 2011 at 2:38 PM
    #294
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol he is really busy i'm sorry man this makes me look like a douche.
    he is coming down again to pick up a new set of housing from me on the 2nd so i will mention it to him again lol he is completely redoing my entire retrofit. they both leak and he blames it on the use of non oem housings.
    i think it's because either he screwed up some where or the housings i sent him have some sort of defect in them they where tyc so as after market housings go they are one of the best but, still have less inherent quality that the stockers by far.
    lol inside the last tyc's i had apart the screws where all different i think they have to do that for fear of copy right infringement or some shit idk lol.
    either way i told him i'd spring for the factory housings for him to work with at my expense btw 450 bucks for a set! lol then he told me that if the parts can't just be switched over he was going to charge me in full again for labor and materials and the parts that he would not be able to use again like the shrouds and rings lol.
    all i know is i hope this dude gets shit correct this time they have been on my truck for a little over a month and have been taken off to be resealed now 5 times!
    edit: lol i do still believe that bjorn lightwerkz and clearcorners.com are the best and only place one should even attempt to go for a retrofit. this guy has been rocking and rolling out probably by now over 2 thousand retros and i have never heard one horror story so i think i just gave him bum housings it could happen i guess.
  15. Dec 1, 2011 at 2:51 PM
    #295
    AsianAnts
    AnT
    Hans, it was not my intention to make you look like a douche :eek:
    but dangggg.. crazy stuff going on man.
  16. Dec 1, 2011 at 2:59 PM
    #296
    Commanderwiggin
    Calgary
    What wire harness relay for a Blazer fog light kit?
    Booking my order right now:
    Blazer Fog Light Stage III Kit
    Wire HarnessRelay: ????????????????????
    ProjectorsBlazer Fog Light Modules (Clear Lens)
    Bulbs880: Morimoto 3Five 5000K
    BallastsMorimoto 3Five (35w)
    Bi-xenon Morimoto Mini Stage III Kit (D2S)
    Wire HarnessRelay: H4/9003
    ShroudsGatling Gun
    Re-sealing Glue Yes
    Projectors LHD (North American Standard)
    CCFL Angel Eyes Yes
    Bulbs Morimoto 5Five 5000K
    D2SBallasts5) Morimoto 5Five 50w
  17. Dec 1, 2011 at 3:06 PM
    #297
    AsianAnts
    AnT
    9145/9006 harness
  18. Dec 1, 2011 at 3:10 PM
    #298
    Commanderwiggin
    Calgary
    Thanks for all your help guys...I have a fair amount of knowledge in regards to this stuff but I always ask stupid questions just to make sure I'm getting the right stuff...and seeing as how I don't have the truck yet...gotta make sure. :)
  19. Dec 1, 2011 at 3:15 PM
    #299
    AsianAnts
    AnT
    if your truck comes with fog lights, you dont need a harness... just saying. mine plugged right in and worked with the OEM
  20. Dec 1, 2011 at 3:22 PM
    #300
    Commanderwiggin
    Calgary
    Perfect...yes it comes with fogs!
    Just pulled the trigger on the GB...add mine to the list lol.
Thread Status:
