TRS group buy: 25% off, Let's see a list! Thanks Matt@TRS!
Discussion in 'Group Buys' started by LEDsolutions, Oct 27, 2011.
Thread Status:
Not open for further replies.
  1. Nov 14, 2011 at 10:17 AM
    #81
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Will do. It is an easy mod from what I have seen in other threads. The only reason I'm doing it is because both my H3 Hyper white bulbs died. I decided rather than spend $50 on 2 new bulbs, I could spend it upgrading to HID. I hope that the reflector is up to the task.
    Unfortunately, my stock 510 SMR bulbs died before I could take a calibrated night shot to do a before and after shot.
  2. Nov 14, 2011 at 2:19 PM
    #82
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    *edit*
    Something came up and I have to back out of the GB. Sorry.
  3. Nov 14, 2011 at 9:45 PM
    #83
    NotFromAroundHere
    NotFromAroundHere Member
    Does anyone know if the re-sealing glue from the drop down box is the same as the OCI butyl rubber glue in their accessories section?
  4. Nov 14, 2011 at 9:47 PM
    #84
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    it is the same.
    sticky, tangy, goooey goodness!
  5. Nov 15, 2011 at 6:37 AM
    #85
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    so looking at that yes you still apply, i know the last group buy was stage 3 or better
  6. Nov 15, 2011 at 12:06 PM
    #86
    viperstd
    Maryland
    Can the OP please verify if we NEED to get a stage III kit to qualify and if the other stuff in our cart will also qualify?
  7. Nov 15, 2011 at 12:08 PM
    #87
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Yes. 25%off any stage III or better kit
  8. Nov 15, 2011 at 12:28 PM
    #88
    viperstd
    Maryland
    Right.. and if I add extra ballasts and bulbs, does that qualify for the discount?
  9. Nov 15, 2011 at 12:46 PM
    #89
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I have been reading a lot on the HID retrofit.
    The actual projector comparison of the Mini and the FX-R is very informative. It seems that the FX-R will project the light further down the road than the Mini. The Mini is an easier install. The cost of the FX-R stage 4 is only $25 more than the Mini with the same ballast and bulbs. At this point I am tempted to go the FX-R stage 4 kit and just dive into the project. One of the saving graces for me is that I have a donor set of headlamp housings that I will be modifying.
    There should not be a problem if I change to the FX-R stage 4 correct?
  10. Nov 15, 2011 at 1:20 PM
    #90
    AsianAnts
    AnT
    In a nutshell:
    -Mini is simple and easier to install indeed. Bake, separate, install, bake, seal.
    -FX-R will need some 'customization'. bake, separate, modify bowl, temp mount fx-r, aim, permantenly mount/install, bake, seal.
    On screen it looks just like a few extra steps. When actually doing the FX-Rs, its alot of trial and test trial and test. Once you have the knowledge it would be a bit smoother. If you do decide to dive into the project and tackle it yourself, I'm more than willing to give you pointers and what not. I'm sure others here would be willing to chime in and give some advice/pointers too.
    Good to have a donor set. My advice, work on 1 headligh first then start the other. Remember to take your time (benefits of having a donor set) :)
    Shouldn't be a problem because I'm pretty sure payment has not been processed. They won't process until 25 orders are set
    -AnT
  11. Nov 16, 2011 at 2:49 AM
    #91
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Shrouds are your personal preference.
    I plan on installing the halo ring inside the Gatling shroud. The pics look pretty decent and you do not have that BMW ring look. The light comes out the vents of the shroud.
  12. Nov 16, 2011 at 4:43 PM
    #92
    AsianAnts
    AnT
    bump, cmon more people gotta be interested!
  13. Nov 17, 2011 at 12:09 AM
    #93
    PMM2008
    PMM2008 New Member
    first of all, I'm grateful that this site has a great amount of people willing to get together to get a great discount. So that said i would like to be included into the list. Is it possible to post this in another forum to see if other people are interested, its not a tacoma forum? if not let me know, pm if i need extra info to give to you guys. thanks interested in FX-R Stage III kit and ccfl.
  14. Nov 17, 2011 at 3:35 AM
    #94
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Skygear and PMM2008:
    Please do a copy and paste from the list on page 4 and add your name to the list. We need to keep track of the members commiting to purchase a kit.
    PMM2008:
    Welcome to Tacoma World. What vehicle are you planning to retrofit?
  15. Nov 17, 2011 at 5:10 AM
    #95
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    well by the time this group buy fills up ill have enough money to pay for these. Im in:
    Bi-xenon Morimoto mini stage III kit (D2S)
    Edit:
    new addition to the list...
    1. LJ_24: Stage III kit D2S
    2. jamesdinan: Bi-xenon Morimoto Mini Stage III Kit (D2S)
    3. lfoster200 : Bi-xenon Morimoto Mini Stage III Kit (D2S)
    4. JRob33: Bi-xenon Morimoto Mini Stage III kit (D2S)
    5. NotFromAroundHere: Bi-xenon Morimoto Mini Stage III Kit (H1) /w Re-sealing Glue
    6.Rojoracing53: Bi-xenon Morimoto Mini Stage III kit (D2S)
    7. Marcmfm007: Bi-xenon FX-R stage IV or new Helas w/ everything needed. Also glue and angel eyes.
    8. AsianAnts: FX-R stage III kit
    9. (spot taken)*
    10. (spot taken)*
    11. (spot taken)*
    12. 95SLE Bi-xenon Morimoto Mini Stage III Kit (D2S) Denso Ballast, Phillips 85122+ bulb, CCFL Angle Eyes, Gatling Gun Shrouds, Resealing glue, H4/9003 Relay
    13.Casey05Taco Bi-xenon Morimoto Mini Stage III kit (D2S) apollo shrouds, bulb: 5000k morimoto 5five d2s, LHD, ballast morimoto 5five 50w, reseale glue, 9006 relay
    14.
    15.
    16.
    17.
    18.
    19.
    20.
    21.
    22.
    23.
    24.
    25.
  16. Nov 17, 2011 at 5:50 AM
    #96
    viperstd
    Maryland
    ** If the discount applies for other items in the cart aswell*** add me for Mini Stage 3, 2 extra 50W ballasts, 4 50W 5k bulbs
    9. (spot taken)*
    10. (spot taken)*
    11. (spot taken)*
    14. Viperstd: pending group buy details (Mini Stage 3, 2 extra 50W ballasts, 4 50W 5k bulbs)
    15.
    16.
    17.
    18.
    19.
    20.
    21.
    22.
    23.
    24.
    25.
  17. Nov 17, 2011 at 6:19 AM
    #97
    dragon
    dragon Well-Known Member
    Calgary
    08 AW DC LB 4x4
    a bit of show & go
    A little confused, would the blazer stage III kit qualify?
    I already have mini ds2's.
  18. Nov 17, 2011 at 8:51 AM
    #98
    cummins6speed
    Not unless you buy a headlight kit as well
  19. Nov 17, 2011 at 10:18 AM
    #99
    PMM2008
    PMM2008 New Member
    The retrofit will be for a 2008 Honda Accord.
  20. Nov 17, 2011 at 10:21 AM
    #100
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Nice. A former coworker, I am now retired, has an accord. I doubt she would be up for a conversion. They are nice dependable cars.
Thread Status:
