TRS Mini H1 HID or 40" LED single row
Discussion in 'Lighting' started by mattvivsound, Nov 20, 2013.
  1. Nov 20, 2013 at 9:59 AM
    mattvivsound
    mattvivsound [OP] Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    The other weekend I had a small wildlife animal commit suicide by 4Runner and I now have to replace the passengers side headlight (cracked the lens). I purchased a pair of new black housings, these are the DEPO brand.
    Since I have new headlights on the way, I am now debating on if I should open up the lights and install the TRS Mini H1 kit.
    Or would it be better to install a $250-300 40" LED bar (single row, 5-10w, combo) on the roof (see Stealth LED light bar install posting) and have it 'switched' on by the high beams.
    Current bulbs:
    Low: Philips Xtreme
    High: Philips HIR
  2. Nov 20, 2013 at 4:09 PM
    mattvivsound
    Southern MD
    Or... what are the Pro's and Con's of each method.
  3. Nov 21, 2013 at 6:11 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Absolutely go with the HID retrofit. It's going to see far more use than the LED light bar, especially on the public roads since it will improve the low beams and high beams.
  4. Nov 22, 2013 at 1:26 AM
    acdronin
    acdronin Well-Known Member
    You aren't going to be able to use those LED's as often as you want, technically they are off road lights and you can't run them on public highways, my big lights are switched independent of the high beams, there's situations for one, the other or both.
