TRS wiring harness help
Discussion in 'Lighting' started by Ultimatemawlcrawl, Aug 30, 2016.
  1. Aug 30, 2016 at 7:19 PM
    Ultimatemawlcrawl
    Ultimatemawlcrawl [OP] Member
    Mark
    2011 DCSB prerunner sr5
    Not much...yet....
    So I want to order the Bi-Xenon: Morimoto FX-R stage III kit for my 2011, only problem is I'm confused on which harness to order with the kit. I already read their article on wiring harnesses, but it all pretty much went over my head. I'm guessing I need to get the can-bus Bi-Xenon H4/9003 harness, correct?
  2. Aug 31, 2016 at 9:10 AM
    Ultimatemawlcrawl
    Mark
    Not much...yet....
  3. Aug 31, 2016 at 12:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW. The OEM bulb is 9003/H4. If you are getting new 9003/H4 HIDs then yes, that is the correct harness. Note that you should not put HIDs in your factory headlights, as this will have uncontrolled beam pattern and cause scatter. You will want to pick up a set of headlight retrofits from TRS in addition to the HIDs.
  4. Aug 31, 2016 at 1:37 PM
    Ultimatemawlcrawl
    Mark
    Not much...yet....
    Thanks man, yea I'm gonna do it with one of their universal application kits, just wanted to make sure that I was ordering the correct harness.
  5. Aug 31, 2016 at 2:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You're welcome. Be sure to post some pics of the results when you are done!
