Tru-Cool transmission cooler #4454 for 1st gen Tacos and 4runners
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by wcp0611, Mar 28, 2014.
  1. May 6, 2014 at 8:57 PM
    #121
    wcp0611
    wcp0611 [OP] Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Also, I'd be willing to trade one to anyone with a 4x4 front mudflap set. I need some pretty bad.
  2. Aug 27, 2014 at 3:01 PM
    #122
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    So I installed the 1st gen one while adding a 3.0 radiator....question is can I run the trans cooler as a stand alone and not hook it up through the radiator also? Our thought behind it is it would run cooler if it wasn't getting hear transferred through rad to trans side. Is the radiator designed to warm the trans fluid up on cold days, so could I run in to the opposite issue of not getting warm enough on cold days?
    Thanks in advance.
  3. Aug 27, 2014 at 6:33 PM
    #123
    LAL00O00
    LAL00O00 Well-Known Member
    Jorge
    San Diego, CA
    2001 TRD Taco
    Which kit fits the first gen tacoma? I have the mud flaps
  4. Aug 28, 2014 at 5:27 AM
    #124
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Sorry man. I already got my mudflap. I don't have any more of these for sale.
  5. Aug 28, 2014 at 7:13 AM
    #125
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    To answer:
    Yes, you can run it alone. Be mindful of the cooler ratings though and be sure to monitor your temps. I don't know how big the aux cooler was, but there was a user that showed his temps going up fast, using both aux and OEM cooler (4th gear accel with lock up clutch off)
    Yes, the OEM design is to help heat up the trans fluid on initial startup and cold days. If you run both in a series, I would recommend running to aux cooler first and the OEM cooler last but not as good as the OEM cooler which actively heats the fluid as the engine warms up.
    This cooler has a bypass design; when the fluid is colder and less viscous, it will bypass the cooling fins and go back to the trans without being "cooled" so generally you wont run the risk of overcooling the fluid.
  6. Jun 10, 2015 at 7:03 AM
    #126
    DesertDigger
    DesertDigger Well-Known Member
    Eric
    Whittier CA
    '00 Prerunner Reg Cab
    TC +3.5 with Kings, BFG KO2 285s on Bronze NVs, Tube bumpers with Hella 4000 converted to HID
    Sub for info and feedback.
  7. Jun 10, 2015 at 7:36 AM
    #127
    DIRT YOTA
    Cory
    Camarillo, CA
    I liked mine. Never really got temps before or after though lol.
  8. Jun 10, 2015 at 10:19 AM
    #128
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  9. Jun 11, 2015 at 1:35 AM
    #129
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    When you guys installed these did you bypass the stock cooler/radiator or poor it in line with this cooler?
