Truck Acceleration Prob After lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Masomase, Jul 16, 2011.
  1. Jul 16, 2011 at 4:43 PM
    Masomase
    Masomase [OP] Member
    WA
    Indigo trd sport
    BHLM
    Ever since I put my lift on I have been having an acceleration problem. It is when I go to pass and I put the accelerator to the floor it doesnt take off, it revs up to fourish and stays going the same speed. I am dumb founded with what is going on with my truck. The lift is a Radflo complete lift kit form toytec I bought TC uppers with them, it is set to 2.5 I do believe.
  2. Jul 16, 2011 at 4:47 PM
    dbronzo
    dbronzo Protected by Armor Tech Offroad
    Dennis
    Fayetteville, NC
    08 TRD Sport 4x4 w/ some Mods
    King Coilovers, LR UCA's, All Pro Sliders, ATO Full Skids, Pioneer AVH-P4300, 4.56 Gears, Front and Rear ARB Air Lockers, ATO Full Wrap High Clearance Bumper w/ Tire Carrier, ATO Hybrid Bumper, Smittybuilt XRC 8, Lightforce 240 Blitz, Rock Lights
    what size tire are you running?
  3. Jul 16, 2011 at 4:51 PM
    Masomase
    WA
    Indigo trd sport
    BHLM
    245/75/17 had them before the lift if that helps any.
  4. Jul 16, 2011 at 4:55 PM
    dbronzo
    Dennis
    Fayetteville, NC
    on that note no, I know that when I lifted and put bigger, heavier tires on that I lost some umph.
  5. Jul 16, 2011 at 5:05 PM
    Masomase
    WA
    Indigo trd sport
    BHLM
    Oh no it it has good power. Just when I floor it to pass someone, it will not accelerate any. It stays at the same speed no matter how long I hold it for.
  6. Jul 16, 2011 at 5:08 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    disconnect the negative terminal for a bit then drive it around, maybe it just needs reset
  7. Jul 16, 2011 at 5:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Go underneath the truck and look around the transmission for any loose wiring. Check TPS and MAF sensors are plugged in. Check your fuel line isn't bent or crimped on something. Is (I know this is dumb) your emergency brake off? Check the emergency brake cables aren't pulled tight.
  8. Jul 16, 2011 at 5:22 PM
    Masomase
    WA
    Indigo trd sport
    BHLM
    I am pretty sure my ebrake isnt on use it now and then. I will go check sensors now.
  9. Jul 16, 2011 at 5:42 PM
    Masomase
    WA
    Indigo trd sport
    BHLM
    Well sensors are plugged in and wires look good, and no crimps in the brake lines. Anything else worth trying? Also unplugged the battery for awhile
  10. Jul 16, 2011 at 6:04 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    O iono...tranny fluid?
  11. Jul 16, 2011 at 6:06 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I'm not a mechanic; I think you need a pro to look at it.
  12. Jul 16, 2011 at 7:11 PM
    Masomase
    WA
    Indigo trd sport
    BHLM
    Yeah asked my cousin who just happens to be a mechanic and he was puzzled, he said get on here and ask since you guys have helped before. I am to scared to take it to the stealership and have them take a look.
  13. Jul 16, 2011 at 7:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Does it feel like the transmission is slipping? Does the engine seem to rev up freely but the truck goes nowhere? Or is it more like the engine is straining and can't accelerate?
    You say it has good power, but stays at the same speed when you floor the gas? That would seem like a lack of power to me unless the engine is revving up but not actually accelerating the truck.
    What else happened during the lift install? Did you mess with any wiring? Drain any fluids and have to refill? Is the check engine light on?
  14. Jul 16, 2011 at 7:32 PM
    babytruck
    NorCal
    Hows the tranny fluid level?
  15. Jul 16, 2011 at 7:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like you mean its not downshifting into "passing gear"...
  16. Jul 16, 2011 at 7:41 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sounds like it is taking a while to unlock the torque converter and downshift to 4th
  17. Jul 16, 2011 at 7:42 PM
    T-Rex266
    T-Rex266 T-Rex Moderator
    Curious what the issue is...
  18. Jul 16, 2011 at 7:43 PM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    thats my thought too your getting the rpms but no umph.....with the same tires there should be no change just a little more wind resistance from the added hieght but not enough to even notice. I would focus on the tranny thats my 2 cents
  19. Jul 16, 2011 at 8:05 PM
    babytruck
    NorCal
    Tranny fluid perhaps?
  20. Jul 16, 2011 at 10:19 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    some cars have a "limp mode" when something is wrong. scan the computer see if anything comes up.
