Truck all over the road,,,anyone else have this prob
Discussion in 'Suspension' started by yfz450ak, Nov 2, 2009.
  1. Nov 2, 2009 at 4:57 PM
    yfz450ak
    yfz450ak [OP] Active Member
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    Ok so when i am driving down the road or freeway the tacoma likes to wonder around in the lanes,,, the steering wheel moves alot,,, it feels like i am driving in the wind but there is none...
    I have 265/75/r16 load E tires air at 45psi and a daystar struct spacer... could that cause a problem...
  2. Nov 2, 2009 at 4:59 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Maybe your tires need to be balanced. Did you have that done when you added the spacers??
  3. Nov 2, 2009 at 5:02 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I think that's a problem with your alignment.
    I'm not an alignment specialist by any means, but I think it has to do with your caster.
    Go google alignments and see if that sounds like your problem, and bring it in for an alignment.
  4. Nov 2, 2009 at 5:03 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    sounds like alignment issues. Not enough caster due to the lift.
  5. Nov 2, 2009 at 5:07 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    My truck does this every time I drink!:D
    On a serious note just wondering but do you feel this behind semis or is it all the time cas the drag from them will pull you around alot!
  6. Nov 2, 2009 at 5:48 PM
    yfz450ak
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    As far a alignment it just got done,,, i did the alignment the day after i installed the strut spacer.... sometime last week,,, i thinking its the strut spacer causing it to walk but i really dont know
  7. Nov 2, 2009 at 5:49 PM
    RelentlessFab
    Eric
    Sparks, NV
    do you have a print out of the before/after specs from the alignment?
  8. Nov 2, 2009 at 6:08 PM
    yfz450ak
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    no i dont,,, i will see if they have at the shop
  9. Nov 2, 2009 at 6:22 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    45 psi sounds like the problem to me....do the psi chalk test it is in the mod list at top of page
  10. Nov 2, 2009 at 10:23 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Yeah I thought my Tacoma wandered a bit even the day I got it before I did any lifting or mods. Seems to be a lack of caster issue. Some corrective UCA's will fix that or you need to tell the shop who aligned your truck to add some more caster. I believe somewhere around 2 is appropriate but my trucks is running 4 due to my UCA's. That's excessive but it definitely doesn't wander now.
  11. Nov 2, 2009 at 10:25 PM
    yfz450ak
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    i will try that
  12. Nov 2, 2009 at 10:34 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    I would have the alignment adjusted with the Camber and Toe set to zero and the Caster set to 2.0-2.4 degrees. Usually wandering problems are caused by a lack of caster which is common when our trucks are lifted. As others have said you might also want to drop your front tire pressure a few pounds to flatten the tire contact patch. Keep in mind that Toyota has broad alignment specs, so just because it is "within spec" does not mean that you won't have tire wear or drive ability issues.
  13. Nov 2, 2009 at 10:37 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    mine was doing that after i lifted/tires & had the tires @ 45psi now I run them @ 36psi and its fine but gas mileage is down abit but zero wandering
  14. Nov 2, 2009 at 11:59 PM
    RelentlessFab
    Eric
    Sparks, NV
    x2. Thats what i've got going on my truck right now.
  15. Nov 3, 2009 at 5:41 PM
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    A lot of shops will call your alignment done even though it's way out of spec (just close as they could get.. always get a printout
  16. Nov 3, 2009 at 10:49 PM
    yfz450ak
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    cool i aired down to 40 psi and if it does it tomorrow i will take the spec above to the alignment shop and see what they have to say,,,thanks guys
  17. Nov 4, 2009 at 1:52 PM
    nelson18matt2
    nelson18matt2 same guy as other nelson18matt
    Ventura, CA
    04 TRD Prerunner
    Icon CO, Camburg UCA, timbrens, bili 5100, deaver J59, glassworks fenders, BFG AT, AR mojave teflons
    my truck wanders on the road too but it's because i need an alignemt like a MO FO. prob similar situation w/ you
  18. Nov 4, 2009 at 2:00 PM
    RelentlessFab
    Eric
    Sparks, NV
    Another thing to consider, certain tires can also lead to an increased feeling of wandering. I've regularly read in tire tests that typically a wider tire will try to track when a vehicle hits a bump, expansion joint, or other inconsistency in roads but this seems to be with tires that are a 12.50 or wider. I know around where I live the roads get a nice groove down them from all the studded tires and chains that people run through the winter and my truck will tend to pull around in them as well.
  19. Nov 4, 2009 at 2:31 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My truck has done this since new...before and after the lift. Like already mentioned, the grooves in the road from tire chains really effect these trucks. I tend to hug the center line, and the truck always wants to pull to the left. When I had a tech drive to duplicate the problem, he drove closer to the shoulder which caused the truck to pull to the right. I've also had problems while tracking in these groves when applying the brakes...the truck pulls to one side or the other. My truck has had the alignment done a couple times. I've also noticed on roads that were freshly paved with no ruts, the truck tracked straight.
