truck battery exploded
Discussion in 'General Automotive' started by muddin, Oct 28, 2011.
  1. Oct 28, 2011 at 8:36 PM
    cc350
    cc350 Retired Member
    Go get some 2 liters of Coke (soda) ;) and dump it on any spots the acid splashed. Then get a wet vac and water to remove soda. The longer you wait the worst it's going to be. Then call insurance.
  2. Oct 28, 2011 at 8:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    isn't coke an acid as well? I do hate chemistry with a passion but Im pretty sure you want a base to cancel the effects of the acid.
  3. Oct 28, 2011 at 8:44 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The main thing is no one got hurt. Anyone have an idea what might have caused that to happen? :confused:
  4. Oct 28, 2011 at 8:44 PM
    jrgroucho
    jrgroucho Well-Known Member
    Jeremy
    Michigan
    2010 AC SR5 BSP
    Hose Clamp, No Seatbelt Chime, Husky Floor Liners, BHLM, sockmonkey Tailgate Decal, Wet Okole Covers/Armrests,
    Yeah, Coke sounds like a bad idea. I think it stems from people using cola to clean off battery terminal corrosion. Battery acid (sulfuric acid) is not the same as corrosion.
  5. Oct 28, 2011 at 8:46 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Going from ice cold from the back of the truck to a sudden warm interior after he's driven? But it should be stronger than that, right? Unless the outside of it was damaged or it was dropped or fell somehow? Corners are a weak point when a heavy item is dropped.
  6. Oct 28, 2011 at 8:56 PM
    Texio
    Texio Well-Known Member
    Austin, TX
    11 4WD DBCab SB
    Coke has a mild acid inside as a preservative, so it probably wouldn't help. The seat would probably be OK by now, it seems like he soaked it pretty well with the baking soda solution, so that hopefully took care of most of it. It might be better to let it dry inside the garage, even better if you had a fan to blow air on it all night so you'd minimize the chances of mold. Maybe even take the covers off.
    Looks like it might be time to jump on a Wet Okole group buy for your seats! :)
    As to what might have caused it, some batteries have very small vents on top to off vapors, maybe it bounced on the seats. Did it fall onto one of its sides? They are really only meant to stay upright, and in my experience some liquid would almost certainly leak out of them if tilted on one side. I don't think it actually "exploded", but more likely some of the liquid just somehow found its way out. Could be because of temperature-related expansion, like babytruck said.
  7. Oct 28, 2011 at 8:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I had a battery explode once. It was dead, trickle charged it back up, put it in the car. Car started fine one time. Moved it ten feet, shut it off. Washed the car, got back in, turned the key. Only sound was the top of the battery blowing off.:eek: Glad the hood was closed. Acid everywhere.
  8. Oct 28, 2011 at 9:01 PM
    Texio
    Austin, TX
    11 4WD DBCab SB
    But that was a battery hooked up to the engine, while this was just sitting on the back seat.
    That sounds terrifying though, glad you were ok! :eek:
  9. Oct 28, 2011 at 9:27 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, don't understand how it would happen with no load on it.
    When mine happened, it was more like a WTF? Moment. I was too young to really be thinking about the what ifs, and it wasn't my car, happened at work. We just hosed the engine bay down and sold the guy a battery. :rolleyes:
  10. Oct 29, 2011 at 3:55 PM
    OffroadToy
    Still trying to figure this one out. OP...In the year of owning the battery was there a chance that it might have been frozen? Are there cracks in the caseing?
  11. Oct 29, 2011 at 4:41 PM
    muddin
    muddin [OP] Well-Known Member
    PA
    2010 Tacoma DC TRD OR
    Bilstein 5100's on all four with some OME 885x's. Brute Force Fab front bumper. Warn winch. Koenig countersteers wrapped with duratracs.
    nope....il check the battery later for any noticable cracks but i did not see any before. i was too worried about the seats.
  12. Oct 29, 2011 at 4:59 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    baking soda can neutralize the acid also
