Truck bed 120 plug in.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bear60263, Aug 28, 2019.
  1. Aug 28, 2019 at 8:51 PM
    Bear60263
    Bear60263 [OP] Member
    2019 TACOMA OFF ROAD
    it appears to somewhat limited, what has people use it for? Just bought a 2019 OR
  2. Aug 28, 2019 at 8:56 PM
    tcjacado
    tcjacado Well-Known Member
  3. Aug 28, 2019 at 10:41 PM
    carverboy
    carverboy Member
    N.C/S.C and Tn.
    2019 Dbl Cab long bed Sport
    subaru tweeters, running boards, plasti diped badges
    I managed to run a three inch angle grinder with mine. Was thinking this is great! Then I went and tried to cut some wood with my circular saw,Failed miserably. Not sure why toyota couldn't make this work with the truck
    running? A larger Alternator might fix it but with my limited electric knowledge no way Im modding that!
    Hemlocktherm78 likes this.
  4. Aug 29, 2019 at 5:49 AM
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    Charge battery packs for cordless tools.
    Run a work light.
    Run a 230 Watt Fender guitar tube amplifier.
    Lava lamp.
    Surgical LASER.
    Iron lung.
    Amazon Echo.
    Seriously? You can't think of anything?
    cshrum, TireFire and shane100700 like this.
  5. Aug 29, 2019 at 6:06 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    So, it is an inverter not a generator. The starting current on AC motors is very high, ohms law where R approach’s infinity, so most good power tools will trip it.
    With any constant draw device is easy to calculate the draw.
    I use mine to recharge portable tool battery’s to and from projects and trouble lights, but rely on house current or a true generator for power tools.
    The inverter is rated for 100W, (ignore the 400w marketing button as peak and starting current are not identical with modified sine wave inverters.). So if the starting current of your device is more than 8.3 amps it will trip the breaker. Keep the load under 8amps. Again, it is hard to calculate starting current, but assume 2x or 3x the loaded current. So a 1/4 HP saw may draw upwards of 10 amps at start up and the momentary draw is even higher.
    In the past, when products where made by people who used them, they would engineer motors with multiple windings and coils to reduce starting current...now everything is made in China so the days of quality have been replaced with days of Walmart pricing only.
  6. Aug 29, 2019 at 6:11 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I once powered a Craftsman Jig Saw with mine just to see if it was possible.
    We tried to power a Foreman style grill/griddle with the outlet in our 4Runner once....we ended up cooking our food over the campfire.
    We also successfully ran an extension cord to the front passenger seat to power a breast milk pump on road trips back when my wife was expressing milk for our infants. That was much better than relying on batteries that were too weak to operate the pump.
    cshrum and Cudgel like this.
  7. Aug 29, 2019 at 6:15 AM
    MaTaco_4x4
    This is a good idea, but I'm unclear how it can be done.
    Can you post high resolution pics, please?
    Thanks.
    TRD-ED, TomTwo, Flash1034 and 2 others like this.
  8. Aug 29, 2019 at 6:19 AM
    MaTaco_4x4
    I recently ran a Lincoln 180 MIG welder from the bed of my truck. It worked perfectly.
    The generator in the bed may have helped.
    Cudgel and TacoManOne like this.
  9. Aug 29, 2019 at 6:19 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I use it to blow up my car camping mattress. Works great
  10. Aug 29, 2019 at 6:20 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Does this suit your needs? Might hurt to use in the fashion you imply.
  11. Aug 29, 2019 at 7:33 AM
    MaTaco_4x4
    I use an M80. Does the job.
    Jojee117, dnlskier[QUOTED] and G59 like this.
  12. Aug 29, 2019 at 7:37 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Power sprayer to stain a split rail fence.
  13. Aug 29, 2019 at 7:39 AM
    SwampThing18
    SwampThing18 Well-Known Member
    2016 MGM Tacoma Sport
    I was hoping to use it to run a small space heater to keep the kid's hockey gear warm in the winter. Not a chance it will run such a power hungry device, is there?
  14. Aug 29, 2019 at 7:40 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    With 400 watts, the rear plug charges phones and iPads faster than the in cab 12v plugs.
  15. Aug 29, 2019 at 7:41 AM
    rnish
    Tacoma 2nd gen
    You have 400 watts. What does the heater draw?
  16. Aug 29, 2019 at 7:59 AM
    SwampThing18
    1500! I didn't realize it was that high. Never mind that idea. lol
  17. Aug 29, 2019 at 8:03 AM
    MaTaco_4x4
    No. Heating is energy intensive, and dino-squeezin's are a better option. Even a 15 amp house circuit won't do what you need. Consider kerosene, propane, or white-gas heaters.
  18. Aug 29, 2019 at 8:32 AM
    dnlskier
    17' TRD SPORT MT
    Anybody try a hot pocket dinner :violent: via bed plug?
  19. Aug 29, 2019 at 8:35 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Here:
    I=V/R
    P=IV
  20. Aug 29, 2019 at 8:47 AM
    rnish
    Tacoma 2nd gen
    Wrap it in aluminum foil, place it on the catalytic converter, run in neutral at 1500 RPM for 5 minutes. Flip it, repeat as necessary.
    Edit: It is not recommended to cook bacon or any fatty meats on your catalytic converter.
    tcjacado and Jojee117 like this.
