Truck bed bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BS1, Aug 10, 2020.
  1. Aug 10, 2020 at 5:29 PM
    BS1
    BS1 [OP] Member
    09 tacoma dbl cab
    Need some help. Trying to get the bolts out from my truck bed (09 tacoma) ive tried everything that i could think of but they wont budge. Sorry if there is a tread out there for this but I couldn’t find one
  2. Aug 10, 2020 at 5:55 PM
    MacGyver15
    MacGyver15 Member
    Nick
    05 Access Cab 4.0 6Spd (Silver)
    You need a T55 socket (which I'm sure you knew) and a breaker bar. Get the 1/2 in drive socket. If you're still having trouble, get a can of penetrating oil such as PB Blaster, and soak the bolts, making sure that it can get down to the threads. Try to find where the bolts come down into the frame from the bed and spray them from the bottom as well. hit them every 15-20 minutes until a solid shove on the breaker bar cracks them loose.
    And remember, righty-tighty, lefty-loosy.
    G3Fab, EdgemanVA and Island Cruiser like this.
  3. Aug 10, 2020 at 6:07 PM
    BS1
    BS1 [OP] Member
    09 tacoma dbl cab
    I will try your idea but i even tried with an impact gun and nothing. Its like they welded these things in lol. Righty tighty lefty loosy that might be my problem
  4. Aug 10, 2020 at 6:10 PM
    Muddinfun
    Muddinfun Well-Known Member
    Yep, spray the threads where the bolt goes through the frame. Then use the torx bit with a breaker bar. Put a pipe on the breaker bar. Work it back and forth. At 1st, it won't feel like it's moving, but keep going back and forth. Eventually, it will start moving. Keep going back and forth. It will eventually go farther and farther. Keep going till it comes out. I have spent 20 minutes on each bolt before.
    Island Cruiser and BS1[OP] like this.
  5. Aug 10, 2020 at 6:12 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    They rust from underneath. Makes it very difficult to get them out.
    I pulled mine early in the truck's life and lathered them in antiseize.
  6. Aug 10, 2020 at 11:35 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Spray as best as you can beneath the heads/washers as well as the threads under the bed every day for a week with PB Blaster. That worked for me and didn’t do any damage
    BS1[OP] likes this.
  7. Aug 11, 2020 at 2:01 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I cut the head and used an 18" pipe wrench and still had to pull hard to break them loose. The Torx head started striping as we all find.
    BS1[OP] and Joker56ace like this.
  8. Aug 11, 2020 at 3:13 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    These are tough, especially if you've never had them out before. Luckily I had removed mine once before when I did the d-rings, so I was able to get them out earlier this year when I replaced them.
    For 5 of the 6, I used a 2' pipe over the socket wrench. Moved it 1/4" at a time. For the last one, I had to use my buddies big ass impact gun. My other friend tried his small impact gun and it didn't budge it. So it does depend on what size impact you're using.
    Either way, good luck. I know something like that can be frustrating.
    corgimas, BS1[QUOTED][OP] and SR-71A like this.
  9. Aug 11, 2020 at 3:36 AM
    rednext
    rednext Well-Known Member
    I ended up having to weld a nut on top of mine and using my big impact to remove it. Stripped the torx out trying to get it out to no avail. It worked really well.
    BS1[OP] likes this.
  10. Aug 11, 2020 at 4:32 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Good to know, thanks! Just ordered a half inch T55 impact socket, and I'm going under the bed to spray the crap out of the bolts where they go into the frame. Guess that's my next project...
    Island Cruiser likes this.
  11. Aug 11, 2020 at 5:12 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Mix 50/50 of acetone/ATF and apply to the bolt overnight. This homemade brew or even liquid wrench would be a better penetrating solution than PB blaster in this situation.
    MacGyver15 and BS1[OP] like this.
  12. Aug 11, 2020 at 5:22 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Drop your spare tire down. Should make it a lot easier to get to the threads that stick out through the frame. And like @Muddinfun said, once you do break them loose, go 1/4 turn out then 1/4 turn in. Then 1/2 turn out, 1/4 turn in, 1/2 turn out, 1/4 turn in. Keep working it like that (even add some more pb blaster to the threads both above and below the frame) until the bolts are a 'normal' level of tightness.
    BS1[OP] and EdgemanVA like this.
  13. Aug 11, 2020 at 8:37 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’m thinking an impact driver, not impact wrench. Mine has a 1/2” square drive on the end, just like a ratchet. Ya know, you put your socket on it; twist then smack it with a hammer. Works great on stripped screw heads too.
    The previous posted saturate with penetrant every day for a week definitely helps.
  14. Aug 11, 2020 at 9:07 PM
    BS1
    BS1 [OP] Member
    09 tacoma dbl cab
    I am spaying it down i got one to move some but not sure if its twisting out or if its gonna snap
  15. Aug 13, 2020 at 5:16 PM
    MacGyver15
    MacGyver15 Member
    Nick
    Any luck with your bolts?
  16. Aug 13, 2020 at 8:10 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I cut the heads off, then punched the remaining bolt through. The nuts are welded to small bars that weren't hard to punch out.
    I welded some flatbar to the flats of some regular hex bolts. The bar engaged the raised parts of the bed, so I could tighten the bolts from underneath. Or you could just use a helper to tighten them
    SR-71A likes this.
  17. Aug 14, 2020 at 9:23 AM
    BS1
    BS1 [OP] Member
    09 tacoma dbl cab
    MacGyver15 not yet i keep spraying them up
