Truck bed cubby holes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomach, Aug 15, 2007.
  1. Aug 15, 2007 at 6:31 PM
    tacomach
    tacomach [OP] New Member
    Can anyone tell me if there is a specific purpose for those open, 4" x 7" cubby holes, one above each wheel well in the bed of my new '07 SR5 Access Cab? I asked at the dealer and they have no idea what they are for. What makes me think these recesses are for some special purpose is that there are a number of small, rectangular holes in the bottom of each, much more complex than simple drain holes. Knowing or not knowing will not change my life, but I am curious and would appreciate it if anyone can tell me the answer. Thanks.
  2. Aug 15, 2007 at 7:15 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    I have not seen any accessories that use them, I always use them to throw my dogs leash, or his tennis balls when I take him out.
    Colojimbo likes this.
  3. Aug 15, 2007 at 8:10 PM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Not sure what there are intended for, I almost never user mine. I do however hate when I load my truck up with mulch/dirt and the cubby holes get crap in them.:cool:
  4. Aug 16, 2007 at 9:17 AM
    TJOPILOT
    TJOPILOT Well-Known Member
    Tie downs in the starboard side and jumper cables on the port side!
  5. Aug 16, 2007 at 10:33 AM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    I've seen somebody mount lights in the holes on another forum.
  6. Aug 16, 2007 at 11:22 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    That'd be PB2themax, and I think the write up on it is either on his cardomain page or atleast linked there.
  7. Aug 16, 2007 at 12:37 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Yes, that is where I saw that mod. Thank you.
  8. Aug 16, 2007 at 1:08 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    yep, exact same stuff that i've got in mine.
  9. Aug 16, 2007 at 10:10 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
  10. Aug 17, 2007 at 12:01 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Lord Humongous likes this.
  11. Aug 17, 2007 at 1:11 AM
    Soul
    Soul Well-Known Member
    07 PreRunner SR5 Black
    ditto that
  12. Aug 17, 2007 at 4:11 AM
    Bfmco7
    Bfmco7 Well-Known Member
    the light mod is an excellent idea!
  13. Aug 17, 2007 at 8:53 PM
    pb2themax
    TRD Sport 4x4
    The thing about that is that the divider is made for the width of the bed. Well, with some tonneau covers the rails get moved inward because of the tonneaus side rails that mount behind the bed rails. To make it work you'd have to cut some metal off of the ends of the divider. I know one guy who did it, and it worked fine.
    The divider was neat, but most of the time it just got in the way. It's not real easy to remove either, when you need to utilize the space of the whole bed.
  14. Nov 10, 2013 at 9:38 PM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Does anyone know the oem part number for these cubbies? I broke the tab on one and im looking to replace it. Thx
  15. Nov 10, 2013 at 9:45 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I mounted my rear differential breather in the driver side cubby.
  16. Nov 11, 2013 at 5:20 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    The tabs do break over time and then they want to fly out on the freeway. Just take some clear or black duct tape and put a small piece on each side to hold it in.
  17. Nov 11, 2013 at 5:38 AM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    I use those cubby holes for EVERYTHING. From bottle caps at tailgating to my dog leashes. I have the locking TuffyBox and the other smaller locking box also. But it's just easy to throw stuff in those cubby holes. Obviously you wouldn't store valuable stuff in them. But I still find them handy for my needs.
  18. Nov 11, 2013 at 5:58 AM
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    I think I am going to use the rear compartment to put a small air compressor and volume chamber in, and the front one to house a valve block, air filter and regulator. hoping it all fits.
  19. Nov 11, 2013 at 8:22 AM
    russtruck
    russtruck Member
    Russ
    Northern California
    Not lockable so not putting anything of value in them.
  20. Nov 11, 2013 at 8:37 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I have a camper shell and a sleep platform on my truck so I use the cubby like a nightstand when sleeping in the back. Throw my phone, wallet, keys, flashlight, etc in when I'm crashed out in the back.
    I married my tacoma likes this.
