Truck bed lower on left side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DarkSky, Mar 26, 2017.
  1. Mar 26, 2017 at 9:59 PM
    DarkSky
    DarkSky [OP] Well-Known Member
    Oregon
    2016 SR5 Double Cab V6 Auto 4X4 Barcelona Red
    I've noticed my truck bed looks low on the left side. I measured at the center of the rear wheel openings and sure enough, it's a little more than an inch lower on the right side (driver side) than the passenger side. Is this something the dealer can fix? I'm coming up on my one-year service in May.
  2. Mar 26, 2017 at 10:02 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    The leaf spring packs are different for the left and right side. You probably have a right side spring pack installed on your left side. Or you could have prematurely worn or broken springs.
  3. Mar 26, 2017 at 10:03 PM
    AKLA98
    AKLA98 Well-Known Member
    Liam
    Boulder, Colorado
    2016 Tacoma TRD OR DCSB MGM
    Bilstein 6112/5160 with Dakar Heavy Leafs, Snugtop Rebel (Windoors, Lighted), Prinsu TopRac, CVT Mt. Bachelor, Falken AT3W, Wheelers Super Bumps, Clazzio Covers, Hardwired Escort Radar, Husky Mats, Morimoto HID's, Baja Designs Yellow Fogs, Caliraised Bumper LED Bar, Interior LED's, Second Skin Deadening, Focal Speakers, PRO Grille, and much more...
    It's the infamous taco lean, caused by the weight of a full gas tank. Check again with a empty tank.
  4. Mar 27, 2017 at 4:09 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Taco lean. Move on.
    shakerhood and minium like this.
  5. Mar 27, 2017 at 4:28 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Maybe you just need to lose a little weight....
    JFick likes this.
  6. Mar 27, 2017 at 4:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    References please?
  7. Mar 27, 2017 at 11:19 AM
    Mudchomp
    Mudchomp Member
    Dixon, CA
    Just chiming in on my experience with the Taco Lean... I have a 2017 DCLB OR, and dealer confirmed it's sagging on driver's side at least 1/2", and visually it looks like crap from the back seeing the tailgate slant towards the driver's side. The dealer opened a case with Toyota, and Toyota said it's within the specs and characteristic of the truck. Whatever.
    Anyways, I took the truck to my local spring shop, and he said he re-arches leaf spring packs all of the time for this issue, Ford, Chevy, Toyota, etc. Usually one side or the other. He's going to re-arch my driver side leaf pack with progressive rate, and will take care of the driver side extra weight (fuel tank, driver) that causes the lean. He looked at my driver's side leaf springs and noticed a bump or flattening out in the middle, which I was told is a resulting characteristic of varying quality between spring suppliers on the assembly line. Crazy. Anyways, I'll be happy to get this issue fixed and have a level truck!
    Oldman808 likes this.
  8. Mar 27, 2017 at 11:21 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Taco Lean... nothing to see hear
  9. Mar 27, 2017 at 12:36 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    It really should be called a toyota lean since the FJ had it as well. I'm sure other models have/had it as well.
  10. Mar 27, 2017 at 12:57 PM
    rluis05
    rluis05 Active Member
    99 Tacoma SR5 3.4
    i have had a '07 and '10 FJ Cruiser and a '97 and '05 4Runner and now a '17 Tacoma and they had it...i always thought it's the gas tank on the left side
  11. Mar 27, 2017 at 1:02 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Damn, something else to check...
  12. Mar 27, 2017 at 1:02 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
  13. Dec 20, 2017 at 8:50 AM
    Jimkola
    Jimkola Active Member
    Jim
    2017 Tacoma 4wd access cab
    Other than shell, stock
    My 2017 Tacoma 4wd access cab is 1.25” lower at left rear compared to right rear. The front measured the same from side to side. You can visibly see the tilt to the left if you park on level ground and view from the back.
    Assuming the gas tank was partially responsible I put weight on the right side. It made no difference. I contacted the service manager at our local dealer who informed me that the lean is due to the suspension design and Toyota has deemed it characteristic of the vehicle. When Toyota uses this terminology it means nothing can be done and the dealer should not make an attempt to correct(otherwise they start the lemon law clock).
    So I contacted Toyota’s National Customer Service at 800-331-4331. I informed them of the concern, also letting them know the local dealer had deemed it a characteristic. Now, And this is important, I told them NOT to just route this back to the dealer as a open contact. This is what they will do 95% of the time. They’ll route you back to the same dealer who already told you there’s nothing they can do.
    I let them the whole reason I called is I think the “design” is NOT desireable and Toyota needs to address the issue and remedy, a TSB. I went on to say the only way Toyota will address is if owners call them and log concerns. I think it’s unacceptable that a new vehicle does this.
    If this tilt bothers you here’s what I recommend:
    1.Take to your local dealer and have your concern documented on a repair order.
    2. After the dealer inspection contact customer service at 800-331-4331. Advise them that routing this back to the dealer is pointless. Request Toyota address the design flaw and remedy.
    3.The rep will document the request And issue you a case number.
    If, at some point a TSB is issued, and your vehicle is out of warranty at that point, you can use the case number and repair order to prove you brought it their attention at an earlier date.(assuming it was under warranty at that time).
    The more people that contact Toyota at the National office the greater the chance something is done. I was told by the dealer that many owners complain of it, but don’t take the time to contact Toyota. Toyota will not listen to dealer input, but they will listen to owners.
  14. Dec 20, 2017 at 9:14 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    The only proper solution to Taco lean is a golden retriever sitting shotgun with you in your truck!
    Key-Rei likes this.
  15. Dec 20, 2017 at 9:24 AM
    Jimkola
    Jim
    Years ago I had a Tercel pull into the service drive. It had a severe lean to the driver’s side. The driver, a woman well above 400 lbs., complained of the lean and the fact her car pulled to the left.
    That was a tricky conversation.
    Key-Rei likes this.
