Truck bed shakes a little. Normal?
Discussion in 'Suspension' started by C0ma, Jan 3, 2025.
  1. Jan 3, 2025 at 1:12 PM
    C0ma
    C0ma [OP] Well-Known Member
    I just noticed when going over a moderately bumpy road that the bed rack shakes a little. I checked the bolt integrity of the entire rack, and all bolts/nuts are nice and snug. I think it's the truck bed itself that shakes.
    Is this normal for trucks? I have a 2020 Tacoma 4x4 Off Road.
  2. Jan 3, 2025 at 1:49 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I've read on here about an issue where the composite bed sort of gets rubbed off/sanded down where the front bed bolts go into the frame. The bed bolts go through a metal sleeve making the bolt tighten against the sleeve, not the bed, probably so you don't crush the composite bed. But the bed can rub on the frame and become loose, able to ever so slightly ride up and down the sleeve that is still fully tight via the bed bolt. To test, go to front corner of bed and lift it and see if you can lift/drop it and get some motion. If none, go to other side and repeat. I currently have this, but it happened to just be the bed bolt being loose last time, so tightening it with an impact was good. I need to try that again, otherwise a spacer of UHMW plastic stuff is recommended between the bed and frame. I have that from when I originally thought it was the issue... so yeah, take a look and report back.
    C0ma[OP] likes this.
  3. Jan 3, 2025 at 2:12 PM
    MGMDesertTaco
    How fast are you driving over the bumps?
  4. Jan 3, 2025 at 2:18 PM
    YF_Ryan
    Kent, WA
    I've found if you drive fast enough you just skip over the tops and it is FAR smoother ;)
    MGMDesertTaco[QUOTED] likes this.
  5. Jan 3, 2025 at 2:49 PM
    C0ma
    LOL. Some Google searchin' indicated that a little shaking is normal for pickup truck beds.
  6. Jan 3, 2025 at 2:50 PM
    YF_Ryan
    Kent, WA
    It don't feel right though, when you can lift your truck bed by hand, let go, and have it clunk, hahaha. Specially when I have a 1200+ pound camper strapped to nothing but that bed!!
