Truck body was hitting sliders, still very close (edited title)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Apr 22, 2016.
  1. Apr 22, 2016 at 9:48 PM
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    So I got my @Pelfreybilt bolt on sliders in and mounted them the day before leaving town. I knew they were too close to the body and a solid hit would cause contact. As it turns out, just bouncing down a potholed forest service road makes the frame flex into the sliders...shit.
    I'm wondering if the Energy suspension bushing kit should keep this flex to a minimum (and maybe bring the body up a tiny bit), or if I should do a small (1/2") body lift? I was so stoked to get these, now I'm a little bummed. Anyone else experience this?
    The bad/ ugly
    The good
    @Socalduckslayer
  2. Apr 22, 2016 at 9:50 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Can't you just bend/hammer the pinch weld out of the way a little bit?
  3. Apr 22, 2016 at 9:54 PM
    Pigpen
    Dan
    Northwest Montana
    Yeah. That's a good idea. I'll probably have to remove the sliders to do it... not the most fun, but probably the best option.
  4. Apr 22, 2016 at 9:55 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Is it normal to need to do that?
    Lot of guys running sliders, can't think of any that had to bend the pinch weld out of the way for them not to contact the body.
    DrFunker and jmaack like this.
  5. Apr 22, 2016 at 9:56 PM
    Pigpen
    Dan
    Northwest Montana
    I was surprised. I've never heard of it before.
  6. Apr 22, 2016 at 9:56 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Just use a pry bar on the pinch and bend it up some
    3coma likes this.
  7. Apr 22, 2016 at 9:58 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Never heard of the need to do this either.
  8. Apr 22, 2016 at 9:58 PM
    Pigpen
    Dan
    Northwest Montana
    With the angle of the sliders, I don't think this will work.
  9. Apr 22, 2016 at 10:00 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  10. Apr 22, 2016 at 10:00 PM
    boostedka
    James
    NM
    Pry from the inside/under the body. I did this on a first gen I had a few years back after i welded then a little too close
  11. Apr 22, 2016 at 10:03 PM
    Pigpen
    Dan
    Northwest Montana
    :thumbsup: That sounds like a good idea. Hopefully I didn't wear through the powder coat today. I'll do that in the morning.
  12. Apr 22, 2016 at 10:03 PM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Did you mention it to Satin? I'm sure she will get you squared away quick.
    ODNAREM and Mobtown Offroad like this.
  13. Apr 22, 2016 at 10:04 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Don't pry until after you've talked to the Pelfrey's, I'm sure if something is out of the ordinary they will make it right.
    DrFunker, ODNAREM, opteron and 2 others like this.
  14. Apr 22, 2016 at 10:06 PM
    Pigpen
    Dan
    Northwest Montana
    I tagged her and Tyler. I really just figured it out today. Plus, they're going through some difficult times with her Dad's health. I don't expect them to see this until Monday. I thought I'd use you creative bastards to help me find a low cost solution.
    I'm going to shoot her an email too.
  15. Apr 22, 2016 at 10:08 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Yeah. I'd just wait. No need to do anything to your rig unless necessary. Maybe they have an idea of how to fix it without bending/hammering at all. If you don't really care, then go right ahead though!
  16. Apr 22, 2016 at 10:18 PM
    Pigpen
    Dan
    Northwest Montana
    So far it's only made contact on the driver side all the way in the back. I might persuade that part out of the way be fore I go wheeling again, probably tomorrow.
  17. Apr 22, 2016 at 10:19 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I notched my pinch weld to prevent any contact
    boostedka likes this.
  18. Apr 22, 2016 at 10:20 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    What I would worry about if it is contacting with no pressure, is if you actually use it as a pivot point, it might bend all the way up into the body. Sliders flex a bit no matter how great of quality.
  19. Apr 22, 2016 at 10:20 PM
    Pigpen
    Dan
    Northwest Montana
    @Mobtown Offroad , any thoughts (other than to suggest that I should have purchased from you ;))
  20. Apr 22, 2016 at 10:21 PM
    Pigpen
    Dan
    Northwest Montana
    This is exactly the concern. I don't really plan to hit them hard - it's my DD. The scars on my frame and skids suggest that it's a possibility though. Edit - As does the big dent in my passenger side rocker panel.
    My concern with bending/ notching to bend is rust. ugh.
