Truck body was hitting sliders, still very close (edited title)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Apr 22, 2016.
  1. Apr 23, 2016 at 9:29 AM
    #61
    stokka
    stokka Well-Known Member
    British Columbia
    2015 DCLB 4x4 SR5
    Considering bolt on sliders, subbed.
  2. Apr 23, 2016 at 9:34 AM
    #62
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  3. Apr 23, 2016 at 9:40 AM
    #63
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    I will say that i went casually off roading in a XJ that I had, on a mild trail. Climbing up a slope my front tire pried out a rock about the size of basket ball- That front tire then fell into the newly created hole and the rocker came down on the rock. It was under light throttle, it was quick- and my first only dent in that rig. Just an example that you never know what you will get into and when my budget allows I will be getting sliders on the Tacoma- Right now I am safe because I have already punctured one of the OEM tire sidewall and have a slight leak in another- so I am not going anywhere until I get a spare.
  4. Apr 23, 2016 at 9:57 AM
    #64
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Don't
    Haha
  5. Apr 23, 2016 at 10:13 AM
    #65
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  6. Apr 23, 2016 at 10:24 AM
    #66
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Like Tyler said, just loosen them and drop them down
  7. Apr 23, 2016 at 10:26 AM
    #67
    300AACTaco
    Alaska
    There's definetly some room for adjustment without shims. I just adjusted mine a few days ago
  8. Apr 23, 2016 at 2:54 PM
    #68
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    10-4 Rubberduck! Just got home from work. I'll crawl under there and see what happens.
    Anyone have any advice on how much space I should be trying to get? @Socalduckslayer? I kind of hope Tyler and Satin aren't working on a Saturday, so anyone feel free to chime in.
  9. Apr 23, 2016 at 3:04 PM
    #69
    Jazz1one
    Jazz1one It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    1/4" maybe? At least that's what Allpro recommends for theirs
  10. Apr 23, 2016 at 3:06 PM
    #70
    Pigpen
    Dan
    Northwest Montana
    I'll see what I can squeak out of them, but that gives me a reference point. Thank you.
  11. Apr 24, 2016 at 9:30 PM
    #71
    Pigpen
    Dan
    Northwest Montana
    @Socalduckslayer , @Pelfreybilt
    Okay, so I made what adjustment I could today. Only the driver side was hitting, so that's all I adjusted - it was raining and sleeting like hell while I had the truck under inadequate cover during the operation. I went out for another run and didn't hear it hit, but It's still closer than I like. I noticed the front of the mounting plate is flush with the bottom of the frame rail, but the mounting holes make it so the plate angles up toward the back. I pushed them down as far as they would go. Here are the pics from today.
    Everything is loosened for adjustment - I wasn't going to take a pic of every bolt...
    Then I leveraged the last square post of the slider down using a pry bar against the rear cab mount. I didn't get much movement.
    You can see that the slider is maxed out - the bottom of the mounting hole is visible below the washer. Notice that the bottom of the mounting plate isn't flush with the bottom of the frame rail. I'm not sure if it's intentionally designed this way, maybe Tyler can chime in.
    This is a shitty pic, but you can see that the mounting plate is flush with the bottom of the frame rail at the front end of the sliders.
    I'm happy that they are no longer hitting the body on road. I imagine they can easily deflect enough to inflict damage. I guess there's a chance my body mount bushings are worn and squished, but the truck is only 4 years old... It's good enough for now as the truck sits. When the weather improves, I'll put the hi lift on them to see how much deflection we get with slow pressure. I might bite the bullet and order a body mount bushing kit to see if that helps. I really like these sliders. They are well made, appear to be plenty beefy, and look great on the truck. IMO the potential for body damage is still too great for me to feel comfortable though.
    Jazz1one and tomwil like this.
  12. Apr 25, 2016 at 8:08 AM
    #72
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I think you are good like you are. I have mine right about the same spot. At the end of the day if you take a hard impact and it comes up enough to touch the pinch weld its not going to hurt anything. My old set of weld-ons on my last truck saw a ton of abuse and they hit hard enough to tap the pinch weld here and there and it just sorta self clears, nothing to be concerned about.
  13. Apr 25, 2016 at 12:51 PM
    #73
    Pigpen
    Dan
    Northwest Montana
    I appreciate you getting back to the thread on this. I'm going to put the hi lift on them as soon as I get the chance to see how much deflection there really is. If a hit deflects them enough to tap the pinch, I won't be concerned. If they touch when I lift the truck, I'll order a bushing kit. For 4 years (since the truck was new) I have carried a full compliment of tools in the rear of the access cab where the seats used to be. Considering that weight and where I drive regularly, I wouldn't be surprised if the bushings are getting a little tired.
    My take away is that I have had a great experience with the Pelfreys in terms of customer service and quality of product. Tyler and Satin are still at the top of my list for my remaining armor. I need my t case skid still - the other 2 are from them - and I will eventually do both bumpers. We're incredibly fortunate to have so many great vendors here on TW!!
