Truck bogging at 30-40mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUNCHBOX66, Feb 10, 2017.
  1. Feb 10, 2017 at 5:50 PM
    LUNCHBOX66
    LUNCHBOX66 [OP] Well-Known Member
    Eric
    2012 white tacoma prerunner
    None so far
    Noticed my 2012 DCSB bogging while driving at 30-40mph. Not sure if it's cause of the fuel I'm using, or maybe something might need a cleaning.
    All maintenance is up to date. Anyone have this issue?
  2. Feb 10, 2017 at 6:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Should be rpm related more than speed. If engine related.
  3. Feb 10, 2017 at 6:43 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    how many miles?
    LUNCHBOX66[OP] likes this.
  4. Feb 10, 2017 at 6:47 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I don't bog my truck at that speed. My Bluetooth drive shaft gets in a bind and causes all sorts of issues.
    desertrunner24 likes this.
  5. Feb 10, 2017 at 6:48 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    :confused:
  6. Feb 10, 2017 at 7:12 PM
    ZachPrerunner
    Southeast TN
    Title :D
  7. Feb 10, 2017 at 7:25 PM
    LUNCHBOX66
    Eric
    None so far
  8. Feb 10, 2017 at 7:26 PM
    LUNCHBOX66
    Eric
    None so far
    There's always a smart ass in the group
    BrokenMech and KingTaco81 like this.
  9. Feb 10, 2017 at 7:50 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    have you cleaned your throttle body and maf sensor
  10. Feb 10, 2017 at 7:56 PM
    KingTaco81
    KingTaco81 The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    X2
  11. Feb 10, 2017 at 7:58 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    Bogging :confused:
    Haha jk buddy.
  12. Feb 10, 2017 at 7:59 PM
    LUNCHBOX66
    Eric
    None so far
    @desertrunner24 that's what I'm doing next. Partner at work said the same thing
  13. Feb 10, 2017 at 9:38 PM
    ZachPrerunner
    Southeast TN
    :stirthepot:
  14. Feb 10, 2017 at 9:38 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    also should have changed plugs at 60k if you did not then do that as well
    NeedmoreTaco likes this.
  15. Feb 10, 2017 at 9:41 PM
    ZachPrerunner
    Southeast TN
    I got my u bolts in today! Thank you once again, I'm hoping I can get them on this weekend.
  16. Feb 10, 2017 at 9:42 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    nice :fistbump: your welcome bud
    ZachPrerunner[QUOTED] likes this.
  17. Feb 10, 2017 at 10:06 PM
    LUNCHBOX66
    Eric
    None so far
  18. Feb 13, 2017 at 10:25 PM
    LUNCHBOX66
    Eric
    None so far
    @KingTaco81 so I cleans out the sensor and throttle body, still sputtering, going to check my plugs next
  19. Feb 13, 2017 at 10:35 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Have you washed the engine bay? Check the plugs and insulators.
    And does it big at other rpm?
  20. Feb 21, 2017 at 1:15 PM
    LUNCHBOX66
    Eric
    None so far
    @monsterkx2fiddy engine bay clean, plugs clean, it will bog/sputter 30-40mph. Notbsire what's my next option
